throttle get stuck! help!
My throttle get stuck. When I let go of the gas, it just stay at 2.5 RPM. I know it's the throttle because I checked. Now, how can I get it to work properly again? I tried using engine cleaner, but that's not working. Any suggestion? What can I remove or use to loosen it up again?
Thanks!
Thanks!
maybe the nut on the throttle is too tight. loosen it. i hope you know which one i'm taking about. it has the throttle cable connect to it.
i had this problem once. mine redline continuously. i had to quickly turn off and pull out the key. it end up being i had somthing in my intercooler and it got suck up and got stuck at the throttle body. scary ****.
[QUOTE=lv6l]maybe the nut on the throttle is too tight. loosen it. i hope you know which one i'm taking about. it has the throttle cable connect to it.
QUOTE]
when i put my new throttle body i had that problem and did what you said in the quote that could quite well be the problem
other then that i would just purchase a new throttle cable what else can you do?
QUOTE]
could be a tight nut on the TB...
could also just be a lot of gunk in there causing it to get stuck. pull of the intake pipe attached to the TB and inspect it for garbage.
clean as necessary
clean as necessary
shabam
Oct 9, 2007 05:10 PM
Slow_h22
Aug 1, 2004 03:25 PM
