How to adjust my 96-98 fogs?
Old Jan 31, 2007 | 07:50 PM
turnsignalandy's Avatar
Default How to adjust my 96-98 fogs?
I just got my password fogs for my 97. I have the square ones. One is aimed higher then the other and I tried adjusting both of them but there dosnt seem to be any movement. How many times should I turn the screwdriver before I see results?
Old Jan 31, 2007 | 07:52 PM
Eran's Avatar
HT White Ops
You have to turn it quite a bit. Also, don't rely on the two screws being in the same position. The brackets may angle differently on your bumper.
Old Jan 31, 2007 | 07:53 PM
Default Re: (Eran)
Im turing the screw that stnads up vertically with the horizantal white cyliner around it, is that the right one?
Old Jan 31, 2007 | 07:55 PM
Eran's Avatar
HT White Ops
Default Re: (turnsignalandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">Im turing the screw that stnads up vertically with the horizantal white cyliner around it, is that the right one?</TD></TR></TABLE>
Yes, but I bet you're turning it the wrong way. You're probably turning it from the top at the cross. You need to put the philip's head in the teeth of the metal wheel around the top and turn. You adjust it like stock headlights
Old Jan 31, 2007 | 07:57 PM
Default Re: (Eran)
no im putting the screw driver in the indentation of the white cyliner, where the little teeth are. I can see the top of the screw moving when I do it, and I tried it on both fogs both ways without results.
Old Jan 31, 2007 | 07:58 PM
Eran's Avatar
HT White Ops
Weird...
Old Jan 31, 2007 | 08:00 PM
pdiggitydogg's Avatar
I really suggest you remove the housings and adjust them by turning the metal screw, from the top, with a phillips head, rather than with that gear thing.
Its more for final adjustment imo
Old Jan 31, 2007 | 08:01 PM
Default Re: (pdiggitydogg)
Ill just use a drill with a philips head on it and go really slow to get some more rotations
Old Jan 31, 2007 | 08:03 PM
you better go pretty damn slow...
the friction from that will melt the soft plastic in that area (trust me)
Old Jan 31, 2007 | 08:06 PM
i was just kidding about that
thegreat0ne
Southern California
15
Sep 6, 2008 05:57 PM
JDM manc 10
Sep 13, 2007 09:58 AM
Takumi Fujiwara
Audio / Security / Video
30
Jan 8, 2006 09:15 PM
hypedlunatic
Nov 24, 2005 04:13 PM
.Ryan
Jun 2, 2004 10:07 AM
