help out i will loose it with this damn electric vss thing.. gsr cluster question in 91 crx
Old Jan 31, 2007 | 05:42 PM
ALLMOTOR CRX's Avatar
Default help out i will loose it with this damn electric vss thing.. gsr cluster question in 91 crx
im having trouble wiring up mine. i just wiried up gsr cluster this afternoon. and when i turned it on to check it everything works great i used this forum...https://honda-tech.com/zerothread?id=1732102 its really great and there is some accurate information on there.. except for pin of the fuel gauge... but im having trouble connecting my vss. i already tried the ecu method where you splice the singal and wire up to pin b6 and ecu but did not work out i got a check engine light when i turned on the car and the speedmeter would go up with my tachometer when i shifted it when down... but tommorow i will try out the other method where you splice signal and wire to pin b6 and b11 on the cluster those it work out fine like that? please let me know how you can connect the damn vss... everything else on my cluster works out great.. i will post some pics of it tommorow thanks...and if i dont figure it out i will call peter from rywire... theyll hood it up right....
Old Feb 1, 2007 | 02:01 PM
mra4886's Avatar
Default Re: help out i will loose it with this damn electric vss thing.. gsr cluster question in 91 crx (ALL
try this one see if it helps.
http://www.ef-honda.com/ben/DCcluster.php
B16Civic93
Feb 21, 2012 02:15 AM
Lazysk8r2
Feb 19, 2012 06:51 AM
4LugR
Jan 22, 2011 07:02 PM
street-crx
Mar 7, 2007 05:14 PM
I LOVE MY EF9
Jan 18, 2004 10:01 PM
