Can a b18b be bored safely to 84 mm?
Old Jan 31, 2007 | 02:18 PM
hotsuma23's Avatar
Default Can a b18b be bored safely to 84 mm?
Is an ls motor bored out to 84mm possible? Because i was thinking its the same as a stock b20 bore. Is it safe to run on an all motor setup w/ itr p73 pistons oversized?? I need to know if this will work reliably thanks.
Old Jan 31, 2007 | 02:22 PM
Phil M's Avatar
Default Re: Can a b18b be bored safely to 84 mm? (hotsuma23)
No, The sleeves are different. 81.5-82.0mm max.
Old Jan 31, 2007 | 02:36 PM
hotsuma23's Avatar
Default Re: Can a b18b be bored safely to 84 mm? (theyoungone)
What will happen if they bore it out to 84mm?
Old Jan 31, 2007 | 03:13 PM
hotsuma23's Avatar
need to know bump!
Old Jan 31, 2007 | 03:37 PM
mx621's Avatar
go and try it, be a pioneer, dont say we didnt warn you
Old Jan 31, 2007 | 03:50 PM
hotsuma23's Avatar
Default Re: Can a b18b be bored safely to 84 mm? (mx621)
i was wrong the pistons are .40 over is it cool to take the block .40 over, also is that 82mm? Thanks
Old Jan 31, 2007 | 05:32 PM
lohatch's Avatar
yes, one mm is roughly .040. putting you are 82mm
1 millimeter = 0.0393700787 inches
hondacrx2
Oct 30, 2007 08:45 AM
j87w
Feb 14, 2005 05:35 PM
GB
Oct 23, 2002 10:00 AM
Westrock2000
May 4, 2002 12:33 PM
