Bad compression in #4
Old Jan 31, 2007 | 02:11 PM
fasil911's Avatar
Default Bad compression in #4
I just randomly did a compression test to see how my engines doing. Here are the results...
All done dry
#1 185
#2 190
#3 185
#4 50
I redid #4 with a few drops of oil and it went up to ~52 psi. So I'm pretty sure it's not worn down rings causing low compression.
I have a 2000 Civic SI with 135,000 Miles. Mods on the car are intake, header, ctr cams, itr springs, and full exhaust with test pipe. I did the valve adjustment about a month ago and there are no ticking valves. The engine is running fine, doesn't lag at all, and there is no smoke in the exhaust.
Old Jan 31, 2007 | 04:42 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Bad compression in #4 (fasil911)
Do a leak down test also. But I suspect that cylinder is dead ie rings like you mentioned.
Old Jan 31, 2007 | 05:03 PM
Runnerdown's Avatar
Default Re: Bad compression in #4 (mar778c)
A few drops of oil will just sit on top of the piston. About a spoonful should be enough to get against the walls where it should be.
Old Jan 31, 2007 | 07:33 PM
h22Sicoupe's Avatar
Default Re: Bad compression in #4 (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">A few drops of oil will just sit on top of the piston. About a spoonful should be enough to get against the walls where it should be.</TD></TR></TABLE>
about a teaspoon is all you need. i suspect bent valves or broken valve springs. a leak down test with a vacuum test will lead you to the problem.
vinuneuro
Apr 25, 2007 10:13 AM
silverboost
Nov 8, 2005 01:01 PM
mafay2
Nov 11, 2004 07:34 PM
DANG YO
Nov 24, 2003 04:26 AM
RedRacerCivic
11
May 22, 2003 10:29 AM
