Anyone have a write up on how to install the H4 harness to OEM Accords?
Old Jan 30, 2007 | 08:13 PM
XaznKewLguyX's Avatar
Default Anyone have a write up on how to install the H4 harness to OEM Accords?
I need a write up on how to install the JDM SiR Accord headlight harnesses to OEM accord headlight harnesses. The H4 harness to OEM.
Old Jan 30, 2007 | 11:33 PM
Default Re: Anyone have a write up on how to install the H4 harness to OEM Accords? (XaznkewlguyX)
nobody ?
Old Jan 30, 2007 | 11:48 PM
rival12's Avatar
I had this done, myself and my mechanic, try doing a search there should be a wiring diagram somewhere here. The fun part is installing the new lights, have to remove the bumper and rebar. goodluck
Old Jan 31, 2007 | 06:37 AM
cpmike's Avatar
cut the stock plugs off and splice the jdm connectors in place. same wire colors.
Old Jan 31, 2007 | 03:39 PM
The-Kid's Avatar
http://suvlights.com/index.php...28f14 find your harness or make your own. eh good luck.
Old Jan 31, 2007 | 03:48 PM
TheMuffinMan's Avatar
He knows where you live!
there's a write up on AD i believe is what i used.
Ordered parts from SUV lights to make a conversion harness and some connectors from Autozone
h4's are dual filament so double check which one you give power to, i believe it's the top socket that you need to wire to
dc4teg95
Aug 27, 2010 06:59 AM
Dan Fizzle
Jan 21, 2009 08:18 PM
Dcsports92
Jun 11, 2008 08:21 PM
amej8
10
May 21, 2007 08:02 AM
Matty.
14
Jan 2, 2006 03:49 PM
