trying to clean this engine. that i have on an engine stand
Old Jan 30, 2007 | 06:54 PM
averyvm's Avatar
Default trying to clean this engine. that i have on an engine stand
I got this motor on an engine stand and im trying to clean it. I got some simple green and and a scrub brush and really does seem like its doing the job
Old Jan 30, 2007 | 06:55 PM
Eran's Avatar
HT White Ops
Honda Non-Chlorinated Brake Cleaner.
$50 a case. You'll use it all.
Old Jan 30, 2007 | 06:57 PM
averyvm's Avatar
Default Re: (Eran)
thats a generous amount of engine cleaner
THC07's Avatar
Default Re: trying to clean this engine. that i have on an engine stand (averyvm)
Purple power @ Napa.
very good stuff
100% biodegradable
edit: and its 4$ a bottle.
sure carb cleaner will work faster, cant compare it to simple green though. either one will clean it to bare pot metal.
Modified by THC07 at 8:08 PM 1/30/2007
Old Jan 30, 2007 | 06:59 PM
Eran's Avatar
HT White Ops
Default Re: (averyvm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by averyvm &raquo;</TD></TR><TR><TD CLASS="quote">thats a generous amount of engine cleaner</TD></TR></TABLE>
I don't mean the entire case on one engine. I just mean it gets used, one way or another. I bought a case about 6 months ago. Went through three cans tearing down a transmission. I've used about four cans since then. It was well worth the money. I like the Honda stuff because it sprays more at once than other brands, and is a more concentrated stream rather than a spray.
Eran's Avatar
HT White Ops
Default Re: trying to clean this engine. that i have on an engine stand (THC07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 &raquo;</TD></TR><TR><TD CLASS="quote">Purple power @ Napa.
very good stuff
100% bio safe
Still the same stuff as Simple Green ... won't touch the power of parts/brake/carb cleaner.
Old Jan 30, 2007 | 07:10 PM
THC07's Avatar
Default Re: trying to clean this engine. that i have on an engine stand (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
Still the same stuff as Simple Green ... won't touch the power of parts/brake/carb cleaner.</TD></TR></TABLE>
you dont think Purple Power can leave the same results as carb cleaner?
Old Jan 30, 2007 | 07:14 PM
Eran's Avatar
HT White Ops
I've used it, and it's just a biodegradable degreaser. It's nowhere near as powerful as brake cleaner for stripping off dirt, paint, oil, and grease.
Old Feb 1, 2007 | 06:40 PM
averyvm's Avatar
do u think the brake cleaner will make the motor look better than this
Old Feb 1, 2007 | 06:42 PM
Eran's Avatar
HT White Ops
Absolutely. It'll make it look a little dry at first. You can always get a Mother's Powerball and some mothers aluminum polsih and go to town.
Old Feb 1, 2007 | 06:44 PM
averyvm's Avatar
Default Re: (Eran)
im definately going to lood into that
Old Feb 1, 2007 | 06:53 PM
EGhatch33's Avatar
yes brake cleaner can make it much better than that
Old Feb 1, 2007 | 08:19 PM
crapanese's Avatar
i brake cleaned and scrubbed my old block with a scotch brite pad. worked soooo good.
CivicEK321
May 1, 2008 06:09 AM
truevietluv636
17
May 17, 2007 03:03 PM
coolrace05
Dec 14, 2005 07:30 PM
matto2413
Mar 3, 2005 04:53 AM
NA JDM GSR
Feb 14, 2005 06:10 PM
