bad rotors?
Old Jan 30, 2007 | 05:00 PM
globy123's Avatar
Default bad rotors?
Hi..I just changed my brake pads today and I noticed about half inch on the outside part of the rotors not smooth with kind of small holes on the metal. Why are there small holes on the rotor metal and how can I fix them?
Old Jan 30, 2007 | 05:10 PM
philosofy1's Avatar
Default Re: bad rotors? (globy123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by globy123 &raquo;</TD></TR><TR><TD CLASS="quote">Hi..I just changed my brake pads today and I noticed about half inch on the outside part of the rotors not smooth with kind of small holes on the metal. Why are there small holes on the rotor metal and how can I fix them?</TD></TR></TABLE>
if you are talking about the side where the pads do not touch, then those holes are for ventalation, and cannot be fixed.
Old Jan 30, 2007 | 05:17 PM
globy123's Avatar
Default Re: bad rotors? (philosofy1)
I'm talking about when you take the tire off and looking straight at the rotor...about half inch on the outside of the rotor has these rusty holes. The inside of the rotor is very smooth. What should I do?
Old Jan 30, 2007 | 05:19 PM
97civicdx's Avatar
Buy new rotors
Old Jan 30, 2007 | 05:22 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by globy123 &raquo;</TD></TR><TR><TD CLASS="quote">I'm talking about when you take the tire off and looking straight at the rotor...about half inch on the outside of the rotor has these rusty holes. The inside of the rotor is very smooth. What should I do?</TD></TR></TABLE>
ok, i'm trying to understand the best that i can. if the rotor is already mounted, the surface that is smooth is the area where the pads make contact. this is how your car stops.
now, if you look on the side of the rotor (rotor still mounted), where it usually does get rusty, then yes, those holes or vents are to cool the rotors down when you are driving.
the only rotors i know with holes on the smooth surface are cross drilled, if you do not have those rotors but have holes on the smooth side, then you should replace those rotors.
Old Jan 30, 2007 | 05:23 PM
globy123's Avatar
Default Re: bad rotors? (97civicdx)
Is it worth it? There is no drag on rotors and no shaking steering wheel. The rotors are 1.5 years old.
Old Jan 30, 2007 | 05:26 PM
globy123's Avatar
Sorry to confuse you. There are no holes on the smooth surface . I should of asked when you're looking straight at the rotor should the entire surface of the rotor be smooth? The edges of the rotor surface where brake pads touch are kind of rusty.
Old Jan 30, 2007 | 05:29 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx &raquo;</TD></TR><TR><TD CLASS="quote">Buy new rotors</TD></TR></TABLE>
great advice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by globy123 &raquo;</TD></TR><TR><TD CLASS="quote">Is it worth it? There is no drag on rotors and no shaking steering wheel. The rotors are 1.5 years old.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by globy123 &raquo;</TD></TR><TR><TD CLASS="quote">Sorry to confuse you. There are no holes on the smooth surface . I should of asked when you're looking straight at the rotor should the entire surface of the rotor be smooth? The edges of the rotor surface where brake pads touch are kind of rusty.</TD></TR></TABLE>
if there is no vibration when braking, and everything is good, you don't need to replace it.
as for the rusty side, this is perfectly normal. then tend to rust due to the excessive heat and wheathering.
Old Jan 30, 2007 | 05:40 PM
globy123's Avatar
Alright..Do you think the new pads may even out the rotors or spend another $80 and machine the rotors?
Old Jan 30, 2007 | 05:53 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by globy123 &raquo;</TD></TR><TR><TD CLASS="quote">Alright..Do you think the new pads may even out the rotors or spend another $80 and machine the rotors?</TD></TR></TABLE>
if you are paying $80 to machine the rotors, you are being ripped off. brand new rotors don't even cost that much.
Old Jan 31, 2007 | 01:52 PM
97civicdx's Avatar
: if you are paying $80 to machine the rotors, you are being ripped off. brand new rotors don't even cost that much.
Thats what I just said,,,,,,,,,,
Old Jan 31, 2007 | 02:26 PM
Osiris94EJ's Avatar
Replace them
thaseint
Suspension & Brakes
May 1, 2007 09:45 PM
JDMproblem
17
Apr 6, 2007 04:26 PM
Takashi1978
May 23, 2005 05:26 PM
professorman
Dec 28, 2003 06:16 PM
LudeyKrus
Jun 10, 2003 03:40 PM
