doing a swap need some help!
Old Jan 30, 2007 | 02:54 PM
Naboost's Avatar
Default doing a swap need some help!
i've got an ls/vtec that i'm dropping into my civic. Story short i'm trying to replace the bearing thats in the flywheel. i'm doing this by hand because i don't have a compressor. i tried using a 12 point 11/6 i believe to take off the bolts on the side of the flywheel with no luck whatsoever. i had my brother hold the flywheel and the bolt just isn't budging. Have any other suggestions how to take it off or is my only resort to go out and get a compressor and do it that way?
Old Jan 30, 2007 | 03:06 PM
2DoorBandit's Avatar
Default Re: doing a swap need some help! (Naboost)
ill try to explain how i do it cause i never use air tools........what i do it thread a tranny bolt into the block and but the bols that hold the clutch in but not all the way then put a flat bar againt them and use a 2 ft breaker bar and bam they all loosen up......im not the best at explaining things so soory if this dosent help
Old Jan 30, 2007 | 03:12 PM
jfruauff's Avatar
first its a 12 point 10mm. Without air tools wow have fun. You could put a socket on the crank bolt and hold that
Old Jan 30, 2007 | 08:50 PM
Naboost's Avatar
Default Re: doing a swap need some help! (jfruauff)
yeah i'm kinda confused.
Old Jan 30, 2007 | 09:35 PM
instrument's Avatar
if you're lucky someone put some loctite on those bolts as well
use the force....if you aren't skilled in the ways of the jedi you will need an impact gun
Old Jan 30, 2007 | 09:40 PM
turbociviccoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfruauff &raquo;</TD></TR><TR><TD CLASS="quote">first its a 12 point 10mm. Without air tools wow have fun. You could put a socket on the crank bolt and hold that</TD></TR></TABLE>
he is talking about the 17mm 12 point. just have someone hold the crankshaft bolt with a 19mm socket and breaker bar while you take the 17mm off.
hope this helps...gl man
jdm206
Oct 5, 2006 04:42 PM
endlessdv
Jan 27, 2005 11:22 PM
VRD^don
Oct 1, 2003 12:08 PM
jondancer
10
Apr 18, 2003 07:19 AM
1 speedstar
Jul 28, 2002 05:03 PM
