cracked manifold please help
Old Jan 30, 2007 | 01:52 PM
civicdxguy's Avatar
Default cracked manifold please help
i just took off the heat shield to exaust manifold on my 96 civic dx hatch and saw that it was cracked. what would be the better choice to replace the stock manifold or go with the ex manifold. how would i fit a cat after the ex manifold setup. which would be cheaper
Old Jan 30, 2007 | 01:53 PM
EL Vap133's Avatar
Default Re: cracked manifold please help (civicdxguy)
Go with the EX manifold, the DX one will always crack.
Old Jan 30, 2007 | 01:54 PM
Luserkid's Avatar
Depends on the what manifold, what state you live in, and what your looking to do. Best bet would be just weld it.
Old Jan 30, 2007 | 01:55 PM
civicdxguy's Avatar
how would i fit a cat after the ex manifolds
Old Jan 30, 2007 | 02:00 PM
punoy69's Avatar
Default Re: (civicdxguy)
get an EX manifold and EX cat and have a muffler shop weld it on Your catalytic converter will be welded onto your remaining exhaust system UNDER the car Mine's cracked as well but I just had it welded shut and its doing fine so far, been going strong for like 4 months
Old Jan 30, 2007 | 02:09 PM
civicdxguy's Avatar
thanks for the help
Old Jan 30, 2007 | 02:10 PM
civicdxguy's Avatar
would the cracked manifold make the engine light come on
Old Jan 30, 2007 | 02:15 PM
projectpd's Avatar
hey i got the same problem with my Ex (canadian built) with a d16y7 . I was told that changing to the usdm ex exhaust setup will cause your car to throw an engine code and run rich !! thats why i am looking for some info as well !! anyone know what we can do to fix this problem ?
Old Jan 30, 2007 | 02:21 PM
civicdxguy's Avatar
someone help us
Old Jan 30, 2007 | 02:26 PM
punoy69's Avatar
my cracked manifold didn't make my CEL go on but it did make annoying noises and to answer the other guy, no it shouldn't throw a code or anything, you'll have to extend the second o2 sensor to reach the cat (which will now be UNDER the car) or I think you can run an o2 sim (someone check that for me) and you'll be fine
Old Jan 30, 2007 | 02:29 PM
projectpd's Avatar
Default Re: (punoy69)
Alright , any ideals if a d15b7 Exhaust manifold and downpipe could fit ? cuz i got a couple d15b7 EM lying around .. Thanks for the quick reply
civicdxguy's Avatar
if my catalytic converter is clogged could that throw the cel
hondajdm311
Honda Civic (2001 - 2005)
Oct 21, 2011 06:24 AM
d16X
Jun 19, 2005 11:02 AM
projectEK9
Feb 27, 2005 05:28 PM
