Dynomax super turbo mufflers!
so im lookin to get one of these cause it seems to have had a good rep, i want a relatively quiet and low tone for cheap! im also getting a kteller 2.5" mandrel piping kit.
the question is that the stock replica that dynomax offers has a part # 17778 and can be found here.
http://store.summitracing.com/...w=sku
it says the inlet is only 2.25" will that restrict the flow if i use it with the kteller pipes?
or should i go with a muffler that has a 2.5" inlet just to keep it even? part #17734
this one is cheaper, unfortunately its only a single outlet. id like to have duals but thats not a huge deal.
so which one should i go with?
I would go with the 2nd because its cheaper for one, and you dont want to bottleneck your 2.5 piping, you might as well keep it all the same... I have it on my rex I would deffenetly recomend a cat or resinator or both because its way to loud with straight piping!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by funkified »</TD></TR><TR><TD CLASS="quote">yea ill definitely be getting a resonator, any recommendations on a size?</TD></TR></TABLE> The longest one you can fit.
Got Milk
13
Mar 28, 2004 12:49 PM
