which jb weld to use
Old Jan 30, 2007 | 01:34 PM
djsire's Avatar
Default which jb weld to use
i have a leak of coolant on my block. it appears to be a crack on the block which was previously jb'ed up by the previous owner. i bought the regular jb one but its taking forever to cure. plus its like 29 degrees outside.
th crack is below the header by the alternator on an h22
is there anythign else that would do a better job?
i cannot afford welding it correctly becasue i dont have a job right now.
Old Jan 30, 2007 | 02:15 PM
gritsak's Avatar
Default Re: which jb weld to use (djsire)
the regular kind is the only jb weld i would use. the quick dry **** is worthless if you are trying to seal something up. You could run a space heater out and blow it on the area to help cure time since its cold, but you are going to have to wait 24hrs regardless to be sure.
Old Jan 30, 2007 | 04:30 PM
djsire's Avatar
Default Re: which jb weld to use (gritsak)
now when you say regular your reffering to the 2 tubes correct?
becaseu the have the other one that is like a bar.
http://jbweld.net/products/jbweld.php
or
http://jbweld.net/products/jbstik.php
or this one i found to be interesting
http://jbweld.net/products/water.php
i included that last one because now i have to drain the coolant to make sure it dosent seep through while letting the above two choices cure?
anymore input?
Old Jan 30, 2007 | 04:43 PM
gritsak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">
This is the one i would use. Definitely dont use the second one, its no good for sealing any pressurized liquid. Ive never used the third one, but it sounds promising. If you decide to use the first one (it is what i would use), Drain the coolant, take sandpaper and scuff up the area, then clean it up really good and make sure its completely dry with no residue on the surface.
Old Jan 31, 2007 | 11:03 AM
djsire's Avatar
ok i did it.
i couldnt really scuff up the area becaseu it was hard to get to. but i cleaned it off with some brake cleaner and dried it up.
then i put copious amounts of the jb weld on there. and smoothed it out. ill let you konw what happens tommorow.
if this doesnt work im gonna try the water weld one.
Old Jan 31, 2007 | 05:57 PM
gritsak's Avatar
If the area was clean and you let it cure the proper amount of time, i think you will be in good shape
Old Jan 31, 2007 | 06:20 PM
djsire's Avatar
**** i just went too look at it and i seen green fluid still.
this doesnt look good.
im gonna pick up the water weld stuff tommorow
Old Jan 31, 2007 | 07:08 PM
gritsak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">**** i just went too look at it and i seen green fluid still.
im gonna pick up the water weld stuff tommorow</TD></TR></TABLE>
did you drain the block completely (or at least below the level of the crack)?? with the regular stuff, if any of the coolant seeped through the crack under the sealing surface, it wouldnt work. Also, it probably needs at least 12hrs? before it really starts to adhere to the surface, then another 12hrs to fully harden. Thats within the reccomended air temps as well.
let me know how the water weld works out. It sounds like it expands as it hardens, so make sure you get it into the crack really well. Ide clean out as much of the other jb weld as you can too.
Old Feb 1, 2007 | 05:51 AM
djsire's Avatar
i dumped everything out the rad.
i dont know how to get the rest of the fluid out
Old Feb 1, 2007 | 05:52 AM
djsire's Avatar
also i cant even see the crack@@@
Old Feb 1, 2007 | 05:57 AM
Howitt's Avatar
use the stuff in a can that looks like rabbit turds. I used it on my delivery van with 400k miles and it stopped the biggest leak you ever seen. or you can pull a myth busters and use an egg
Old Feb 1, 2007 | 07:02 AM
gritsak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">i dumped everything out the rad.
i dont know how to get the rest of the fluid out </TD></TR></TABLE>
well theres your problem. the block is filled with coolant as well, you have to take a bolt out in the back of the block to drain it.
i dunno what to tell you about not being able to see the crack. since the JB weld didnt seal well, you should be able to take a knife or something and wedge it under and pry/pop the jb weld off for the most part.
Old Feb 1, 2007 | 07:59 AM
djsire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gritsak &raquo;</TD></TR><TR><TD CLASS="quote">
i dunno what to tell you about not being able to see the crack. since the JB weld didnt seal well, you should be able to take a knife or something and wedge it under and pry/pop the jb weld off for the most part. </TD></TR></TABLE>
do you have pics of the drain plug?
i have exavtly 24 hours to get this done
Old Feb 1, 2007 | 08:32 AM
gritsak's Avatar
i'de say your best bet now is to try that water weld stuff. Since it expands as it gets hard, it shouldnt matter that the coolant is still in the block (at least thats what it seems from the description).
Old Feb 1, 2007 | 10:49 AM
djsire's Avatar
ok i used the cheap epoxy stick that you rub with your hands. (couldnt find the water weld)
and so far its working!!!!!
i ran the car for about 30 minutes and not a hint of leakage.
im taking it for a spin now.
Eyger
Paint and Body
Mar 9, 2009 01:08 PM
PissedoffHONDA
May 23, 2008 08:21 AM
dunkd
Jun 30, 2004 12:25 AM
LudeyKrus
Nov 29, 2003 06:19 PM
SOUNDEFFECTS
Nov 26, 2002 07:23 AM
