ecu fuse blows when converting to obd1
Old Jan 30, 2007 | 11:52 AM
88hfef8's Avatar
Default ecu fuse blows when converting to obd1
hey, my friend swap a b20 into his 90 hatch and wanted to convert to obd1. when he turn the key the ecu fuse blows. it only thing is that, it only blows when it obd1, also his fuel pump doesn't come on. we've check the jumper with another jumper and theres nothing wrong with it, also he has changed the ecu. i've searched and didn't find anyone with the same problem can anyone help me?
Old Jan 30, 2007 | 11:59 AM
88LXi68's Avatar
Default Re: ecu fuse blows when converting to obd1 (88hfef8)
There has to be a bad ground somewhere.
Old Jan 30, 2007 | 12:06 PM
fsteclipsegst01's Avatar
try looking at every wire after the harness. maybe something is cut a little and hitting sumthing. or since u guys did a motor swap too... look for stranded wires.
Old Jan 30, 2007 | 01:25 PM
88hfef8's Avatar
Default Re: (fsteclipsegst01)
alright but why is it that when he goes back to obdo it doesn't blow the ecu fuse and his fuel pump works
jdmspice
11
Sep 21, 2012 08:14 AM
91efbluehatch
Nov 5, 2011 03:54 PM
fabe85
53
Jun 7, 2011 11:40 AM
liquidrider
Feb 16, 2010 05:00 PM
JDM00SI
Mar 29, 2006 10:35 PM
