high compression head gasket or removing layers off Honda OEM one ?
Old Jan 30, 2007 | 08:10 AM
lude98SH's Avatar
Default high compression head gasket or removing layers off Honda OEM one ?
Are both safe which will raise compression more but be safe ? BTW the high comp gasket is a cometic.
Old Jan 30, 2007 | 08:13 AM
mgags7's Avatar
cometic makes good products
Old Jan 30, 2007 | 11:37 AM
Missing Gears's Avatar
Default Re: (bb4ever)
you can use the bottom layer of the oem gasket, it works very well i have done several. i believe that is what spoon was selling as their thin gasket.
Old Jan 30, 2007 | 02:01 PM
94Vtecluder's Avatar
Default Re: (Missing Gears)
They're pretty much the same thing. Most will tell you hondata and spoon headgaskets etc. are merely OEM ones with a layer removed.
Old Jan 30, 2007 | 05:23 PM
lude98SH's Avatar
Default Re: (94Vtecluder)
Generally how much does that raise compression because i believe i read that most "high compression" gaskets raise it about .2 or so. Correct me if im wrong.
Old Jan 30, 2007 | 07:51 PM
92hondalude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">They're pretty much the same thing. Most will tell you hondata and spoon headgaskets etc. are merely OEM ones with a layer removed. </TD></TR></TABLE>
hondata dosent make headgaskets....do they?
Old Jan 30, 2007 | 08:40 PM
ethereal2pt2's Avatar
Default Re: (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">Generally how much does that raise compression because i believe i read that most "high compression" gaskets raise it about .2 or so. Correct me if im wrong. </TD></TR></TABLE>
that's what i'd like to know. and wouldn't removing a layer reduce durability, increasing the tendency to warp nd such.
Modified by _BB6 at 7:49 PM 2/4/2007
Old Feb 4, 2007 | 06:17 PM
Lubo_25's Avatar
Default Re: (_BB6)
cometic makes different bore sized gaskets with thicknesses...much more reliable right?....hmmm
Old Feb 5, 2007 | 05:05 AM
hu's Avatar
hu
Default Re: (_BB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BB6 &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by _BB6 at 7:49 PM 2/4/2007</TD></TR></TABLE>
No kidding. I dont want a blown head gasket.
Old Feb 5, 2007 | 05:12 AM
Default Re: (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">
No kidding. I dont want a blown head gasket.</TD></TR></TABLE>
better not buy a spoon gasket than.
theres nothing wrong w/ a single layer headgasket. why dont you people try these things for yourselves and then come back on here and let everyone know how it worked?
Old Feb 5, 2007 | 05:35 AM
people have been using a single layer of the factory gasket since 20+ years ago, its nothing new. it does work and your head will not be any hotter weather using a 30 tou or a 10 thou gasket.
try it for yourself sometime and learn something.
Old Feb 5, 2007 | 07:41 AM
alterdcreations's Avatar
for every .030" take off = 1 point in compression of the h22 heads.
Old Feb 5, 2007 | 08:08 AM
mgags7's Avatar
Default Re: (alterdcreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">for every .030" take off = 1 point in compression of the h22 heads.</TD></TR></TABLE>
its not that linear bud. do the math. the first .03" you take off might be 1 point. The next time its gonna be more.
Old Feb 8, 2007 | 08:49 AM
lude98SH's Avatar
Default Re: (mgags7)
Which layer do you use and typically how much will that take off ? How thick is each layer ?
Blue94Accord
Oct 23, 2010 04:00 PM
PhatBoy5015
Mar 12, 2006 11:27 AM
turbotime
Nov 5, 2005 08:45 PM
xyzalvarez
31
Sep 5, 2005 09:54 AM
infra
Aug 6, 2004 11:43 AM
