do i need the brake master cylinder for the ls rear disk
Old Jan 29, 2007 | 10:44 PM
$racer1's Avatar
Default do i need the brake master cylinder for the ls rear disk
well i just did a 90 ls rear disk on my 90 si hatch....i didn't change anything inside the engine bay. Do i need to change the brake master?how bout the brake booster? Some people tell me yes and some tell me no??? Please help
Old Jan 30, 2007 | 12:19 AM
fourthgenhatchB17's Avatar
Default Re: do i need the brake master cylinder for the ls rear disk ($racer1)
No u dont, you'll be fine.
Old Jan 30, 2007 | 03:55 AM
ozrednsx's Avatar
Default Re: do i need the brake master cylinder for the ls rear disk (fourthgenhatchB17)
a 4040 prop valve if you havent done so
Old Jan 30, 2007 | 06:10 AM
hondaman86's Avatar
no you don't have to change the master cylinder or the booster, but it helps to run a 15/16 master cylinder. You will need to change the proportioning valve.
The last few posts on this thread is useful info on which prop. valve to use.
www.honda-tech.com/zerothread?id=1561371
Old Jan 30, 2007 | 12:41 PM
$racer1's Avatar
Default Re: do i need the brake master cylinder for the ls rear disk (hondaman86)
alright thanx for the help
Old Jan 30, 2007 | 09:51 PM
drastikmeasurez's Avatar
Old Jan 31, 2007 | 01:04 AM
jackinthetrunk's Avatar
Default Re: do i need the brake master cylinder for the ls rear disk (drastikmeasurez)
I changed mines only because I ran the TEGs front brakes too. But damm my crx had too much braking power after that.
Old Jan 31, 2007 | 03:36 AM
DaNnYsEvEn's Avatar
Default Re: do i need the brake master cylinder for the ls rear disk (ozrednsx)
EDIT: n/m didnt see the link
fryman
Aug 7, 2015 06:49 PM
JBLAZE622
Jan 8, 2009 05:53 AM
CivicVX94
16
Oct 17, 2007 07:40 PM
whole9
10
Mar 30, 2007 10:00 PM
