Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Real Time Managment D17?
Old Jan 29, 2007 | 08:51 PM
DEIVIONCRX's Avatar
Default Real Time Managment D17?
Is there any decent Engine Managment for the D17 ECU?
A Setup with software for DIY tuning would be the best option, as it wont be going on a D17
Old Jan 29, 2007 | 08:54 PM
Vantage's Avatar
Im confused here, u want engine management for a d17, but it wont be used on a d17?
only options for d17 are EMS and Emanage.
Old Jan 29, 2007 | 10:01 PM
DEIVIONCRX's Avatar
Default Re: (Vantage)
yes i need management for a D17 ECU, but the ECU will not be powering a D17 Motor
ok ill check out EMS and EManage
Old Jan 29, 2007 | 10:08 PM
Miracle's Avatar
Default Re: (DEIVIONCRX)
You won't find anything that belongs to a D17 ECU, but won't power a D17...
That is just like saying, "I need a B series ECU, that will run a K series. " It just won't happen.
Old Jan 30, 2007 | 02:30 AM
DEIVIONCRX's Avatar
Default Re: (Miracle)
yea it will happen its not a problem, i just need to know what engine managments are out there for the D17 ECU's
edit: the only thing stoping you from using a Bseries ECU on a Kseries is the DIS, otherwise it would only be a problem of making the Kseries Sensors match the Bseries Sensors and it would run just fine, with proper Fuel and Ignition tables
but this isnt what im talking about, i just need to know what engine managment systems there are for the 01-05 Civic EX/LX/DX
Old Jan 30, 2007 | 05:24 AM
Vantage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEIVIONCRX &raquo;</TD></TR><TR><TD CLASS="quote">
And no, there are a LOT more to ecu's that u think. Anyway i gave u ur answer.
Old Jan 30, 2007 | 12:19 PM
DEIVIONCRX's Avatar
i know how much there is to ecu's, an ecu doesnt give a crap what motor its running, all it cares is it gets the right signals, all it does is say when ive got X TPS, X TDC X CKP, ect.... i will signal the injectors to fire X times and i will fire the coil... NOW!, it could be a ford desiel on the other side as long as you get the right signals to the ECU it wont matter
There is a KA-T 240SX in town that runs a DSM ecu, why because the DSM ecu is cheeper to modify, insted of buying a Standalone, he can get the DSM ecu Chipped for next to nothing, car runs perfect
Old Jan 30, 2007 | 12:27 PM
fventura03's Avatar
i guess this is thinking outside of the box, in for updates
Old Jan 30, 2007 | 01:09 PM
DEIVIONCRX's Avatar
Default Re: (fventura03)
i will deffinatly reply if this is what happens
Old Jan 30, 2007 | 01:12 PM
GJHondaMan's Avatar
Default Re: Real Time Managment D17? (DEIVIONCRX)
deivioncrx has a point. an ecu is just a computer. so as long as all the periferals are talking it'll work great. i work with hvac controls and its the same thing. sometimes you have to do some tweeking to make a sensor work but as long as the computer can read the info it doesnt care whats happengin to it or where its coming from. way to think outside the box deivioncrx. props
Old Jan 30, 2007 | 01:24 PM
potatostix's Avatar
Dude you forgot about that uber secret wire that nobody knows about that tells the ecu weather its a K20, B16, or a D16...
Duh!
nick91civicsi
Engine Management and Tuning
Oct 25, 2009 03:27 PM
SlammedPSD
Jun 10, 2008 11:48 AM
shahmiezan
Jan 19, 2007 05:39 AM
89civichatchback
Jan 18, 2003 07:58 AM
