Honda S2000 Honda S2000
How much boost can the stock s2k map sensor read?
Old Jan 29, 2007 | 07:17 PM
EJ8 GSR-T's Avatar
Default How much boost can the stock s2k map sensor read?
As stated how much boost can the stock s2k map sensor read?
Old Jan 29, 2007 | 08:20 PM
Mase's Avatar
Default Re: How much boost can the stock s2k map sensor read? (EJ8 GSR-T)
about 10.5 psi
Old Jan 29, 2007 | 08:36 PM
EJ8 GSR-T's Avatar
Default Re: How much boost can the stock s2k map sensor read? (Mase)
and what kind of replacment does it need to be able to read more?
Old Jan 29, 2007 | 09:09 PM
TomTomTuning's Avatar
The Stock S2000 Map Sensor i believe is 1bar
1bar = 14.5 psi
What kind of Management system are you running
Alot of times those companys make higher Bar Map Sensors
like AEM, Holly etc
Typically ppl use GM 3bar Map Sensors
They are all universal for the most part
3Bar = 43.5 Psi
Old Jan 30, 2007 | 07:05 AM
EJ8 GSR-T's Avatar
Default Re: How much boost can the stock s2k map sensor read? (TomTomTuning)
it will be running the HKS f-con pro...im just a bit worried becuase on my ej8 the stock sensor was said to read one bar but that only translated to about 9.9 psi...and to make any real power with the s i am going to need more than that.
Old Feb 1, 2007 | 09:28 PM
GoFaassttt's Avatar
Mase is right ... between 10.5 to 11.0 is the max the stock map sensor can read.
Old Feb 1, 2007 | 11:34 PM
riceball777's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TomTomTuning &raquo;</TD></TR><TR><TD CLASS="quote">The Stock S2000 Map Sensor i believe is 1bar
1bar = 14.5 psi
like AEM, Holly etc
3Bar = 43.5 Psi</TD></TR></TABLE>
you need to subtract for automosopheric phressure which is 1 bar
so most ppl run the gm 3 bar map sensor. which mean it will read up to 2 bars but in reality they read up to 29psi max
Old Feb 2, 2007 | 06:42 AM
SuzukaBlueAP2's Avatar
Default Re: How much boost can the stock s2k map sensor read? (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">
right...I thought since it was a 1 bar MAP sensor, it is able to read the atmospheric pressure which is all around us. By introducing more than that the MAP will throw an error.
That's how it was on the B-series Honda MAP sensors anyways. Hence the use of the 'missing link' bypass valves or the installation of a 2- or 3- bar MAP sensor.
44.1 psi (3 bar) - 14.7 (atmospheric pressure) = ability to read 29.4 PSI of boost.
(in theory)
Old Feb 2, 2007 | 01:35 PM
liam821's Avatar
25 Year Member
Default Re: How much boost can the stock s2k map sensor read? (SuzukaBlueAP2)
Most honda sensors are 1.75bar sensors - so they can read to around 10-12psi like Mase said...he would know better then anybody here im sure.
Tofurky
Feb 24, 2019 06:09 AM
hatchBK4life
Feb 3, 2010 12:08 PM
Honda4life777
Jul 6, 2009 09:00 PM
SilverPanda
Oct 9, 2007 01:16 AM
B16Civic93
Apr 2, 2005 09:39 AM
