not getting power to the ecu ?need help plz
Old Jan 29, 2007 | 06:37 PM
EK FLY's Avatar
Default not getting power to the ecu ?need help plz
just finish my swap
running into some problems
INFO:
99 cx hatch
99 ex COUPE engine wire harness (one pice )
obd2b to obd1 jumper harness
obd1 p72 ecu
THE PROBLEM :
well not getting power to ecu , i did a test light on the yell/black wire on the center connector of the wire harness and nothing AND NO power on the no.39 fuse in the under dash fuse box what could be . i have no spark nor the fuel pump is priming
help plz
and i when I turn the ingnition to the II I dont have a CEL light or anything like that
thanks
Old Jan 29, 2007 | 06:57 PM
EK FLY's Avatar
Default Re: not getting power to the ecu ?need help plz (super-hatch)
plz someone help me plz plzplzplzplzlz
Old Jan 29, 2007 | 09:31 PM
Turbogixxer's Avatar
Check:
Main relay
Engine harness (if all the connectors are connected)
Old Jan 30, 2007 | 02:09 PM
EK FLY's Avatar
Default Re: not getting power to the ecu ?need help plz (Turbogixxer)
all right I have a question on ur answer
obd2b 99 ex engine coupe harness on the ecu end it has a green male plug that should go on the green female plug chassis harness right ?
Old Jan 30, 2007 | 04:13 PM
EK FLY's Avatar
so far i been testing all fuses and N0. 31 is not getting power wich in the manual say
no.31 wire color is blu/wht ecm/pcm , pgm fi main relay , integrated control unit
from were is this wire coming from ?
thanks
mudandrox
Jun 3, 2016 10:10 AM
fastraver
Mar 30, 2013 02:37 PM
trevek10
Nov 9, 2011 08:09 PM
EK FLY
14
Jan 31, 2007 01:11 PM
mikensu
Apr 4, 2006 01:03 PM
