Transmission codes
Old Jan 29, 2007 | 03:06 PM
hawaiianhana's Avatar
Default Transmission codes
Hello all, I'm fairly new to this Honda scene and recently acquired an LS-VTEC with trani and wanted to know if there's a code reference guide somewhere on this site to determine what kind I have. thanks
Old Jan 29, 2007 | 03:07 PM
Syndacate's Avatar
Default Re: Transmission codes (hawaiianhana)
It's the same as your ECU code.
The ECU for a D16Z6 (5th gen Si/EX) is a P28.
The tranny for this motor is also a P28.
Follows accordingly.
Old Jan 29, 2007 | 03:12 PM
It came with a Chrome race ECU. Is there a code stamped somewhere on the trans that would give me this info, or do I assume it's an LS trans since it's an LS-VTEC (B16 head with B18B block). Thanks again.
Old Jan 29, 2007 | 03:16 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawaiianhana &raquo;</TD></TR><TR><TD CLASS="quote">It came with a Chrome race ECU. Is there a code stamped somewhere on the trans that would give me this info, or do I assume it's an LS trans since it's an LS-VTEC (B16 head with B18B block). Thanks again.</TD></TR></TABLE>
I am pretty sure it is stamped on the trans.
They say assumption is the mother of all expletive-ups.
State your RPM at like, 80mph.
Somebody could tell you based on the gearing ratios.
Just bring it to a certain MPH (above 30) and analyze the RPM, somebody could help you from there. If not, I'll come back and tell ya what tranny it is . I have to leave now. Go test drive your car and tell me what the RPM are at a certain MPH.
Old Jan 29, 2007 | 03:17 PM
Bense's Avatar
Default Re: Transmission codes (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">It's the same as your ECU code.
Follows accordingly.</TD></TR></TABLE>
No it's not.
Syndacate's Avatar
Default Re: Transmission codes (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">
No it's not.</TD></TR></TABLE>
EDIT:
NVM
Maybe it's P20/B000 - though I dunno what's stamped on the tranny, just find a MPH and tell us the speed you are going and at what RPM it was at (specifically) and somebody could tell you what tranny it is from there - unless it's using customized ratios, which is quite possible, though unlikely.
EDIT 2:
Wow, I am very sorry, I was looking at the Ex (my) tranny name...
Whoops, sorry.
Heh, yeah, like he said, Y80/S80
My bad, sorry.
Anyways, method still proves sound, just got to a certain MPH and tell us as exact of an RPM as you can. The honda tachs are a bit off but somebody could make a judgment as to the tranny based on the gear ratios there.
Old Jan 29, 2007 | 03:23 PM
pdiggitydogg's Avatar
you get a TON of misinformation...
The tranny is probably an S80 or Y80
The problem in that is both LS and GSR transmissions use that stamping - the only way to tell is what rpm you are in @ certain mph....or by opening it up and counting teeth on gears/look of the diff
That will determine your final drive and gearing.
It could be b16/itr (but I dont know the codes for those)
Old Jan 29, 2007 | 03:26 PM
Heylookits shawn's Avatar
Default Re: (pdiggitydogg)
00 si trannies are s4c, integra transmissions are almost all stamped the same, s/y-80
itr trannies and si trannies share the same gear ratio's, only the itr has a limited slip diff. my itr tranny tachs about 4.5k at 80 mph, i think gsr's are closer to 4k, not sure what ls's are. hope that helps
Deadlock281
Sep 4, 2008 07:23 AM
GWInquisitor14
Jan 25, 2005 07:37 PM
done
Oct 8, 2002 03:52 PM
