changed the axle/tie rod yea i searched
Old Jan 29, 2007 | 01:56 PM
Six1oooEG's Avatar
Default changed the axle/tie rod yea i searched
well my car 89 civic si has 345k on the body/motor
car was fine before i lowered it on some cheapo coilovers. i threw the stock suspension on and it still has this problem...
whenever i make left truns the car makes a skipping thudding noise while driving any time the noise is there, when i drive straight or make right hand turn there is no noise everything is fine. now ive replaced the left axls, the driver side outer tie rod and still the problem continues.
everything is tight ive double checked the suspension ie fork , lca bolt, both ball joint bolts etc
the boots for the iner tie rods are rippd on both sides i did catch notice too this but i dont think thats the cause of the problem the car was perfect before i lowered it something happened with me dropping the dam car.
anyways wat could it be bad lower /upper ball joint? spindle?
Old Jan 31, 2007 | 11:40 AM
Six1oooEG's Avatar
Default Re: changed the axle/tie rod yea i searched (Six1oooEG)
bump
Old Jan 31, 2007 | 01:48 PM
sanimalp's Avatar
$cat /dev/urandom
your wheel bearings might be going bad, 345k is a long way for wheel bearings, if they were never replaced. its probably good to do both in the front. and you may want to replace the other axle as well, just to completely eliminate it from the equation.
those inner tie rods would be a good thing to do also, and ball joints if they havent recently been done.
Old Jan 31, 2007 | 01:54 PM
Tyson's Avatar
if the steering rack boots are shot, its pretty much guaranteed the rack end bushing (steering rack) and possibly the inner balljoint (inner tie rod) is toast too.
the good news is that its not that expensive really to replace.
$10 for the bushing. about $40 each for the inner tie rods.
the bad news is that its kind of a pain to replace the first time. but definately doable. dont forget to adjust the gearbox before youre done.
https://honda-tech.com/zerothread?id=1117870
btw, if the problem occurs when making LEFT hand turns, then its the RIGHT side that needs to be replaced.
you said you replaced the driver side... you should have replaced the passenger side.
upper and lower balljoints are also a likely problem. but it should be obvious if they have play by shaking. any play is unacceptable.
Old Jan 31, 2007 | 03:23 PM
Six1oooEG's Avatar
Default Re: changed the axle/tie rod yea i searched (Tyson)
very helpful info thank you.
i jus checked the bottom ball joint and the bushing is shot so im gonna go ahead and replace the spindle itself but ive got a ????? will the spindle from a 92-95 civic work? ive got my parts car eg jus sittin there, but i wana kno before i pull things apart.
this scenario is really weird. i booght the car drove it all the way from MD to PA(about 200mi) drove fine no noise, suspension was fine etc park it in my garage let it sit for a good month, i lowered it drove it out then back in once, moved it a total of 20ft if that.
then i decide to raise it since i got it registered and the problem was there...
i did notice that the car sat and still sits lower on the driverside where i have the problem i duno guys....
thanx 4 the help so far
Old Jan 31, 2007 | 03:25 PM
Tyson's Avatar
no you cant use eg spindles.
but if you can properly extract the balljoint, then you can use it on the ef.
but why bother, just get a new balljoint if thats what you need.
rjmq06
May 23, 2015 08:00 AM
MegustaVtec
Nov 25, 2013 10:01 PM
hybrid90
Suspension & Brakes
14
Feb 27, 2008 03:35 PM
poison
11
Jul 30, 2006 01:34 AM
Sohc Driver
Mar 11, 2003 08:19 PM
