? about Del Sol OEM strut bar...
Old Jan 29, 2007 | 01:21 PM
MugenRcr's Avatar
Default ? about Del Sol OEM strut bar...
I was wondering if the front upper strut bar (OEM version) from a Honda Del Sol (not sure but I think it comes off of the Si version) would bolt up to my '94 Honda Civic DX hatchback? Thanks
Old Jan 29, 2007 | 01:43 PM
bmoua's Avatar
yea the front strut bar from a del sol, em1, or gsr...will work youlll have to drill holes though.
Old Jan 29, 2007 | 01:46 PM
MugenRcr's Avatar
where exactly will the other holes have to be drilled?
Old Jan 29, 2007 | 01:47 PM
MonkeyBoy668's Avatar
Default Re: ? about Del Sol OEM strut bar... (MugenRcr)
Del Sol upper strut bars mount to a 2nd set of bolts that are located above the shock tower. In other words they have their own dedicated 4 bolts, unrelated to the 4 shock tower bolts. If your car has these extra 4 bolts, then it should mount.
They're located to the outside of the strut bolts, on the bulge above where the upper arm mounts.
Old Jan 29, 2007 | 01:50 PM
bmoua's Avatar
pop your hood...you see two small holes on each side...drill through there...you can buy the bolts, screws, and washers at a hardware store or get them from honda. I bought mines at the hardware store. You'll see where to drill trust me. There oval shaped holes, make sure when you put the bolts in to hold the strut bar you stick the bolts from bottom up, not from top to bottom. So basically you'll have to tighten down the bolts from the top not from under the fender wells. HOpe this helps haha...
here are some pics...
Modified by bmoua at 3:19 PM 1/29/2007
Old Jan 31, 2007 | 05:25 PM
MugenRcr's Avatar
Thanks everyone for your help, I really appreciate it
ghost95delsol
Sep 26, 2006 10:57 PM
93EH6
Dec 27, 2002 09:09 PM
spacemanspiff
Dec 26, 2002 12:40 PM
alexbyoung
Dec 24, 2002 02:58 AM
topher
Feb 15, 2002 01:08 PM
