Radiator fan problem
Old Jan 29, 2007 | 12:57 PM
borat's Avatar
Default Radiator fan problem
Recently my car has been overheating when idling at a standstill. The fans aren't coming on reliably, although they did come on when I turned the car off. I tried unplugging the connector from the switch on the thermostat, but they stayed on. Then I unplugged the connector from the coolant temp sending unit (the one under the distributor), and the fans then turned off. They came back on when I plugged that back in, but then turned off again as soon as I started the car up. What is the most likely culprit? The relay, fan switch, or the temperature sender?
therhett17
Aug 13, 2015 09:07 AM
MyRed98Civ
Jan 11, 2014 06:51 PM
Shade93
Apr 13, 2010 01:15 PM
89HFlikeamutha
Aug 13, 2004 01:18 PM
4U2NV
Jun 14, 2004 11:46 AM
