motor shaking
Old Jan 29, 2007 | 09:25 AM
yesSiReK's Avatar
Default motor shaking
it's shaking like krasie. it was fine the other day now the motor is shaking and i don't know wat it could be any ideas?
cwf1988's Avatar
Default Re: motor shaking (yesSiReK)
motor mount maybe,, i mean does it run fine
Old Jan 29, 2007 | 09:26 AM
medside's Avatar
Motor mounts, probably the back one, especially if you did a motor swap.
you should prob. let us know what you had done to the car, so its easier to diagnose
Libertariat's Avatar
Ek Forever y0!
Default Re: motor shaking (cwf1988)
In for motor/tranny mounts.
Old Jan 29, 2007 | 09:32 AM
yesSiReK's Avatar
Default Re: motor shaking (medside)
well everything is stock so i guess i'll check the mounts... umm where are they...? =X and another question i changed the spark plug wires and they seem a little longer then the previous ones... is that ok?
Old Jan 29, 2007 | 09:34 AM
cwf1988's Avatar
the mounts are located on each side of the engine bay,, check them theyhold the engine in place
Old Jan 29, 2007 | 09:38 AM
yesSiReK's Avatar
where are the mounts in the back and the ones for the tranny or are they all the same? oh and wat should i be looking for? to see if they're damaged? like cracked or something?
Old Jan 29, 2007 | 04:25 PM
BLUIZE256's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yesSiReK &raquo;</TD></TR><TR><TD CLASS="quote">wat should i be looking for? to see if they're damaged? like cracked or something? </TD></TR></TABLE>
yeah, they would be cracked more than likely
if you need a visual to see what your lookin for then go to google photo's and type in civic motor mounts and i'm sure you'll find somethin
Old Jan 29, 2007 | 04:33 PM
hatch4life187's Avatar
Default Re: motor shaking (BLUIZE256)
yeah my motor use to shake like a **** my motor mounts were cracked like a bitch got new one and doesnt shake anymore.
Old Jan 29, 2007 | 04:42 PM
Smoak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yesSiReK &raquo;</TD></TR><TR><TD CLASS="quote">well everything is stock so i guess i'll check the mounts... umm where are they...? =X and another question i changed the spark plug wires and they seem a little longer then the previous ones... is that ok?</TD></TR></TABLE>
No one caught that he said he changed the spark plug wires... are they in the right firing order???
Old Jan 29, 2007 | 05:49 PM
yesSiReK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUIZE256 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, they would be cracked more than likely
if you need a visual to see what your lookin for then go to google photo's and type in civic motor mounts and i'm sure you'll find somethin</TD></TR></TABLE>
aite sounds good thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smoak &raquo;</TD></TR><TR><TD CLASS="quote">
No one caught that he said he changed the spark plug wires... are they in the right firing order???</TD></TR></TABLE>
and yea they are, everything is the same before i changed out for new wires but they are a little longer then my old ones. bad thing? doesn't matter?
Modified by yesSiReK at 7:42 PM 1/29/2007
Old Jan 29, 2007 | 06:12 PM
Mr. Giggles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yesSiReK &raquo;</TD></TR><TR><TD CLASS="quote">well everything is stock so i guess i'll check the mounts... umm where are they...? =X?</TD></TR></TABLE>
I'm assuming from this post that you also don't know how to remove your mounts..The rear one is a bitch, so just check the other two and that should narrow down what you might need to replace.
Driver Side Mount:
1. Put a jack on your tranny with a wood block to protect your ****, then jack it up until there is pressure between the wood block and the tranny.
2. Then I'm not sure how many nuts and bolts there are on your mounts, but it's pretty self explanitory, if you have any questions, consults your helms/haynes manual or PM me. There should be three bolts going through your mount. There are two nuts on each bolt wich requires you to use two wrenches to take them off..
3. Then check the mount for damage...When putting the mount back in, make sure your have a pry bar because the bolts might no go back in the way they came out lolz.. So just make sure you have a pry bar to position the mount to nudge the side bolt back in correctly..!!
Tranny Mount(Passenger side mount):1. Position your jack just like you did for the driver mount and put pressure on the tranny
2. There should be four bolts on this mount, one of which is going through the mount which is securing it to your bracket and the other three bolted to your transmission. Take those nuts and bolts off and you got your tranny mount off..!
3. Then expect your mount for damage
Those 2 are the easiest of the three to take out which will narrow down what might need to be replaced.
Ps. I also based this on my car which is a CRX so the number of bolts i stated etc might be wrong, but i basically wrote what you needed to do to take them off..
You can also just look at the mounts and might be able to see damage, but actually taking the mounts off will give you a better idea of what's wrong.
Old Jan 29, 2007 | 06:39 PM
yesSiReK's Avatar
Default Re: motor shaking (SmrCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmrCRX &raquo;</TD></TR><TR><TD CLASS="quote">I'm assuming from this post that you also don't know how to remove your mounts..The rear one is a bitch, so just check the other two and that should narrow down what you might need to replace.
Driver Side Mount:
You can also just look at the mounts and might be able to see damage, but actually taking the mounts off will give you a better idea of what's wrong. </TD></TR></TABLE>
awesome dude thanx i'll take a look tomorrow
Old Jan 29, 2007 | 07:07 PM
awesome dude thanx i'll take a look tomorrow </TD></TR></TABLE>
Yea if you have any questions just pm me and I'll try to help and clarify a little better what i wrote.
seadonkeyraypiss
Apr 4, 2009 10:49 PM
Knightmare69
10
Sep 25, 2006 12:56 PM
civic_driver
Nov 1, 2005 10:22 AM
T3h HoTT!!
Nov 29, 2004 08:18 PM
gezer
Aug 19, 2004 12:05 PM
