upper rad hose and valve cover gasket b16a?????
what up world! well hope yall can help me out!... i finished my swap 2 weeks ago.... i want to change my valve cover gasket but havent been able to find the right application to use. i've used the following app. 1992 teg gsr, and 1995 del sol which are the same the del sol gasket i ordered saturday looked real close it was an after market piece made by rock gaskets.... also im having an upper radiator hose issue... im using my original radiator which the neck is has smaller diameter than the water outlet from the haed i also used the 1992 teg application and it doesnt work!!!! help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sneakerfern »</TD></TR><TR><TD CLASS="quote"> i also used the 1992 teg application and it doesnt work!!!! </TD></TR></TABLE>
yes it does you just gota use a hose clamp and tighten it alot.
well the way the teg hose is molded. ithas a kink comong out of the head outlet... u know anything on what valve cover to use????????the 95 del sol application was close but didnt work out??????????!!!!!!!
i used ITR upper radiator hose but there are others that will work. i thought it fit well and i am happy with it. (i also have a 90-93 integra radiator with the larger inlet/outlet as opposed to the crx radiator. )
all B-SERIES VTEC valvecover gaskets are the same. if it didnt work, you did something wrong.
bellinoracing
16
Jan 3, 2011 03:30 PM
90civichbsi
Sep 12, 2002 08:49 PM
