Which harness to use on a b20z
Old Jan 28, 2007 | 08:22 PM
S2k Hybrid's Avatar
Default 99-00 ex harness on b20z, need help with wiring
I purchased a 99-00 ex harness for my b20z and I need help with wiring. I am using a LS intake manifold, im not sure if its JDM or USDM but let me know if theres a difference. Also I purchased a 95 LS header, OBD1 p75 ecu and a jumper harness OBD2B to OBD1. This set up is going in my 00 Si (I dont have a Si harness). I wanted to know exactly which plugs need to be extended and if necessary is which plugs need to be swapped. I have a b20z harness as well as the flathead intake manifold if that helps
Modified by S2k Hybrid at 8:24 AM 1/31/2007
Old Jan 28, 2007 | 08:23 PM
S2k Hybrid's Avatar
Default Re: Which harness to use on a b20z (S2k Hybrid)
I'm not 100% sure but isn't there a site that offers the part numbers? I can't remember of the top of my head
Old Jan 28, 2007 | 08:25 PM
gezzuzz's Avatar
your 00 si don't have a harness?
Old Jan 28, 2007 | 09:39 PM
S2k Hybrid's Avatar
Default Re: Which harness to use on a b20z (gezzuzz)
obviously not if im looking to buy a harness
Old Jan 29, 2007 | 11:47 AM
S2k Hybrid's Avatar
Can someone check this part number for me? I was told it's an 99-00 EX harness for manual transmission car. The part number is 32110-P2R-A00(3). I put the last 3 in parenthesis because the person selling this harness said he's not sure if they use the last 3 for the part number. Sounds weird to me but I whatever
Old Jan 29, 2007 | 12:11 PM
S2k Hybrid's Avatar
helloooooooooo someone knows the answer and that someone is you the reader
btw the honda dealer isnt picking up the phone, what else is new
Old Jan 29, 2007 | 07:45 PM
S2k Hybrid's Avatar
Are you guys serious? No one can help me out with this? Son of a %(*^#*(^%(&
Old Jan 29, 2007 | 09:58 PM
fmrprojects's Avatar
so your car right now has no engine or nothing. if so then just get the ex harness and extend it
Old Jan 30, 2007 | 09:35 PM
S2k Hybrid's Avatar
Default Re: Which harness to use on a b20z (fmrprojects)
I ended up buying a 99-00 ex harness but some of the plugs dont reach and to be honest, this harness looks like a headache for a b20z. Do you know which plugs need to be extended? I also have the original b20z harness just incase I need to do some surgery
Old Jan 31, 2007 | 06:49 AM
S2k Hybrid's Avatar
anyone?
Old Jan 31, 2007 | 06:52 AM
pdiggitydogg's Avatar
you probably have to extend the evap purge and iat connectors (swapping the latter too)
at least thats what I did on my ls swap into ej8
Old Jan 31, 2007 | 07:09 AM
S2k Hybrid's Avatar
Default Re: (pdiggitydogg)
Can you tell me which color the wires are for the evap purge and the iat? I'm very confused at the moment. I think theres a few more plugs that need to be extended but I cant seem to figure it out. This was so much easier on my 96 ek, I purchased a 96-98 ex harness and used it on my 01 gsr and it worked like a charm.
Old Jan 31, 2007 | 07:33 AM
iat is red/yel
evap is blk/yel
I cant say if you need to extend more than that...I just know thats all I did to mine. My injector wiring was a little on the short/tight side too, but the did reach with a little creative routing through the intake mani runners
Old Jan 31, 2007 | 07:38 AM
S2k Hybrid's Avatar
Thanks, I also had to change the obd1 injectors to obd2 since the harness is obd2.
Old Jan 31, 2007 | 07:43 AM
EG_GSR's Avatar
Default Re: 99-00 ex harness on b20z, need help with wiring (S2k Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2k Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">I purchased a 99-00 ex harness for my b20z and I need help with wiring. I am using a LS intake manifold, im not sure if its JDM or USDM but let me know if theres a difference. Also I purchased a 95 LS header, OBD1 p75 ecu and a jumper harness OBD2B to OBD1. This set up is going in my 00 Si (I dont have a Si harness). I wanted to know exactly which plugs need to be extended and if necessary is which plugs need to be swapped. I have a b20z harness as well as the flathead intake manifold if that helps
Modified by S2k Hybrid at 8:24 AM 1/31/2007</TD></TR></TABLE>
you are going to need a 99-00 si harness or a 96-98 ex harness to make it work without changing plugs. if you use your 99-00 ex harness you will have to change the dizzy plug to make it work for the OBD2 dizzy
Old Jan 31, 2007 | 07:47 AM
I just thought...perhaps youre having length difficulties, because youre mixing up the map and tps connectors?
Switching them around would make it short for the iacv...
map wiring: yel/red, grn/wht, blk
tps wiring: grn/blk, yel/blu, blk
Old Jan 31, 2007 | 07:52 AM
S2k Hybrid's Avatar
Default Re: 99-00 ex harness on b20z, need help with wiring (SOHC_EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_EK &raquo;</TD></TR><TR><TD CLASS="quote">
you are going to need a 99-00 si harness or a 96-98 ex harness to make it work without changing plugs. if you use your 99-00 ex harness you will have to change the dizzy plug to make it work for the OBD2 dizzy</TD></TR></TABLE>
the b20z dizzy plug actually fits on the 99-00 ex harness
Old Jan 31, 2007 | 07:56 AM
S2k Hybrid's Avatar
are those wire colors the same on any car? I had legth issues and also It seems like I had a couple extra plugs besides the vtec plug.
Old Jan 31, 2007 | 08:09 AM
It doesnt list any other color for 96-98 vs 99-00, in helms.
Youre going to have an extra connector, for knock, too.
On my swap, I want to say I had 3 extra - vtec, knock, crank (but thats because my block is pre 96)
Old Jan 31, 2007 | 01:13 PM
EG_GSR's Avatar
what about the harness plugs on the driver side? if those work them in will work
Old Jan 31, 2007 | 01:39 PM
whit3's Avatar
to do this you will need to get the climate control, heater core and motor blower out of a 96-98. this is different then a 99-00. with just the stock wire harness you will be fine but you will need a 0bd2B to 0bd1 jumper. the car is wired correct as is but you will need to extend shorten some of the wires give in the harness. it is easiest to stick with the 99- then to swap and rewire. research the climate control swap to find out if you think it is worth it. as far as the intake mainifold it should be converted to obd2 eventhough you have a jumper cause you still need to deq.
good luk
alexpr
Jun 6, 2010 03:40 AM
562daybid
Mar 23, 2008 06:29 PM
S2k Hybrid
10
Feb 2, 2007 08:29 AM
D3U1LT
Jan 24, 2005 10:47 AM
Cnote
Aug 13, 2004 06:11 AM
