d15Z1 vtec head
Old Jan 28, 2007 | 07:12 PM
silverboost's Avatar
Default d15Z1 vtec head
i picked up a d15z1 head, is this good for a d16y7 block and the d15z1 vtec setup? how much do these heads retail for?
Old Jan 28, 2007 | 08:15 PM
Default Re: d15Z1 vtec head (silverboost)
bump i wanna vtec my y7
Old Jan 28, 2007 | 08:19 PM
HCJDM1's Avatar
Z1 ... ? you know how much Hp the engine as a whole has ?
Old Jan 28, 2007 | 08:20 PM
Syndacate's Avatar
~50 bucks?
100 maybe.
Old Jan 28, 2007 | 08:25 PM
HCJDM1's Avatar
Default Re: (Syndacate)
get a Z6 head Z1 doesnt have much Hp boost .. i think... not entirely sure
heres a link on a b15z1 build
https://honda-tech.com/zerothread?id=1670633
Old Jan 28, 2007 | 08:30 PM
Syndacate's Avatar
Default Re: (HCJDM1)
Y8'll pack more and he won't have re-wire the dizzy nor use different injectors.
Old Jan 28, 2007 | 08:33 PM
HCJDM1's Avatar
if he puts a Z6 head he'll have to change the fule injetors and reiwre the dizzy ?
Old Jan 28, 2007 | 08:34 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCJDM1 &raquo;</TD></TR><TR><TD CLASS="quote">if he puts a Z6 head he'll have to change the fule injetors and reiwre the dizzy ?
Yes, his current motor is OBD-II
to make the OBD-I (Z1) head work you'll have to use OBD-I injectors and cut off an OBD-I dizzy plug and match/solder the ends onto the ends of a cut off dizzy harness plug.
Old Jan 28, 2007 | 08:37 PM
HCJDM1's Avatar
ok that make more sense ... i was thinking he had a D15b7 and wanted to put a z1 head on ... that make alot more sense to put y8 in ..
Old Jan 28, 2007 | 08:44 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCJDM1 &raquo;</TD></TR><TR><TD CLASS="quote">ok that make more sense ... i was thinking he had a D15b7 and wanted to put a z1 head on ... that make alot more sense to put y8 in .. </TD></TR></TABLE>
Not to mention it has slightly higher compression than the Z6 head.
mr arizonas pop
10
May 23, 2012 06:04 AM
neroren
Mar 16, 2009 04:26 PM
95ejjj
Oct 23, 2005 04:49 PM
90efSI
Northwest (Sales)
Oct 9, 2005 01:43 PM
Layziebtnh055
Apr 29, 2004 01:44 PM
