HELP!!!!! DEAD EG!! :(
Old May 16, 2002 | 10:33 PM
CHONCH's Avatar
Default HELP!!!!! DEAD EG!! :(
not mine thankfully, but my friend's 92 si. we were driving along normally, and all of a sudden it started to putter out, and it died. we concluded that the distributor was making no spark, so we went and bought a new one, hooked it up, still the same thing it is getting fuel, the starter is turning the motor over, but there is no spark happening-----and the distributor is brand new, and the wires and plugs are in good shape. if anyone has any ideas, post em', cuz im all tapped out on this one.
later
Old May 16, 2002 | 10:48 PM
TheIntegraGuy's Avatar
Default Re: HELP!!!!! DEAD EG!! :( (twinturbobb)
later
did you reconnect all the spark plug wires in the correct place? try changing the spark plugs..they're only like $10 so its worth it...the ones he has right now might be okay..but you never know. Try doing the same to the wires also...if all else fails, do a self diagnostic and find out what codes the engines throwing and go to jdmfan.com to check what's happening..good luck.
[Modified by J-MiGiRL702, 7:49 AM 5/17/2002]
Old May 16, 2002 | 10:56 PM
NiiS's Avatar
i assume you replaced the cap/rotor-check the old one for cross arc. if you got a re-built dist, take it back for another...no fouling w/ plugs?
btw: if engine light never came on than you'll get no code from a diag-no?
hondas are SO notorious for shitty distributors
Old May 17, 2002 | 01:48 AM
tooqwik1's Avatar
Default Re: HELP!!!!! DEAD EG!! :( (sinnister)
check the ecu fuse in the engine bay
Old May 17, 2002 | 10:26 AM
SpeedRacerEX-R's Avatar
Default Re: HELP!!!!! DEAD EG!! :( (tooqwik1)
Put a screwdriver in the plug wire and arc it to a good ground. If it sparks, then your plugs are bad or your engine isn't grounded.
Reedy
22
Oct 8, 2021 10:05 AM
Sturg
Oct 27, 2009 12:04 AM
crxion91
Jan 19, 2008 12:35 PM
viprcr1
Feb 3, 2007 07:41 PM
famos1
Jul 20, 2004 03:40 AM
