UGR manifold
Was really interested in the BLOX cast manifold but after reading some of the problems people have been having, I got discouraged. Defintley dont want to be shaving my VC/cyl head, or use an elbow etc. So I came across this on Ebay. It looks pretty good. I think im goign to grab it. What do you guys think?
http://cgi.ebay.com/ebaymotors...QrdZ1
why not just get the meutek one off ebay, a lot of people are having great luck with them i have 2 friends that run and love them! sure you have to grind the block a tiny bit but its not big deal. plus is that mani even AC compatible?
I dont see how it isnt, its an exact copy of the Blox except I think the runners are longer
I liek the Muetek as well, but this one is more like a inlinepro and looks like it shoudl flow. Either way, if its exactly the same quality as a BLOX and is redesigned to eliminate the problems, Im gona buy it. No one here has used one??? Guess ill be the first
regarding flow, one of my buddies has the meutek on his lsv and has run it as high as 20 psi on a t3/t04e with no creep. the reason im saying the UGR one might not be ac compatible is because if it was that easy to make a cast mani that was ac comptible and didnt require block shaving then dont you think that HKS revhard drag and blox would have though of it first?
it a good manifold i have it on my car with ac and a 3inch downpipe there also a sponcer on here i made 303@10 psi with the mani on my gsr so it will make good power also and no creep and good responce also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">why not just get the meutek one off ebay, a lot of people are having great luck with them i have 2 friends that run and love them! sure you have to grind the block a tiny bit but its not big deal. plus is that mani even AC compatible?</TD></TR></TABLE>
I have a meutek brand new for sale, decided to go a different route with my setup. getting rid of a/c etc.. 90 plus shipping
Just fitted a ugr mani with an sc34 on the b18c5 block. I had to shave the block a bit but it fits really good. I have not fit the tial 38mm on it yet but I have seen pictures of it fitting without having to use an elbow on a vtec head. I really like the fit and finish of this manifold. I got it for $300 shipped from spoolin performance which included ceramic coating inside and out.
B18ceed
May 31, 2006 12:00 AM
