Dumb question but I was wondering if anybody would have a good guess.
like I said it's kind of dumb but I was hoping to someone might give me a serious answer rather than just flaming me.
I am wondering what kind of numbers I can expect at the wheels with this set up:
D16Z6 (yes I'm building up a d-series purley for the experience before I turbo it and do a bigger build on a GSR motor in the next few years)
70,000 miles everything works fine right now I have 116whp with short ram (AEM), S2 66mm throttle body, S2 intake manifold, DC 4-2-1 header and 2.5 inch exhaust (mandrel bent)/high flow cat and S2 muffler, it has been tuned with an Apxie V-AFC II on a dyno, I have lightend it up a but (stripped the trunk, and taken off the PS and AC, also it has a MSD 6Al ignition.
I plan on having the head ported and polished, ARP head studs, S2 valves, retainers, springs, adj. cam gear and either a stage one or two cam (it is a DD so I'm still looking into the reliability of the cams) then getting it retuned. I'm not trying to make a 12 sec car but I want a responsive DD and to use it on the track during the weekend. Anyway does anybody have a good idea of what kind of numbers I might expect?
if you are gonna do any further modification than i reccomend that you get some high pressure fuel injectors. I did a dyno with my car a year ago and it read 412 hp with 30 lb injectors. I installed 100 lb injectors (not gonna be cheap) and it put it at 438 to the wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mk2machine »</TD></TR><TR><TD CLASS="quote">if you are gonna do any further modification than i reccomend that you get some high pressure fuel injectors. I did a dyno with my car a year ago and it read 412 hp with 30 lb injectors. I installed 100 lb injectors (not gonna be cheap) and it put it at 438 to the wheels.</TD></TR></TABLE>
He has more then enough fuel. Adding bigger injectors will do nothing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fibercation »</TD></TR><TR><TD CLASS="quote">id say areound 130-145 to the wheel</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">
He has more then enough fuel. Adding bigger injectors will do nothing.</TD></TR></TABLE>
/thread.
/thread.
95bkeg
Aug 26, 2006 06:30 PM
95bkeg
Jun 20, 2006 07:45 PM
