s20 synchro hub ?
Old Jan 28, 2007 | 01:44 PM
seabass10369's Avatar
Default s20 synchro hub ?
ok so I am in the process of rebuild an s20 p20-b000 trans and I have a broken 3/4th synchro hub at least thats what I call it. it is on the mainshaft here is a picture
and i check majestic honda and from what i can tell i cant buy just that part it is part of the gear set, now the rebuild kit i am using just has the brass sychros itself plus bearing and seals but i need to get a new one of these pieces does anyone sell them or am i stuck buying the whole gear set below is the like to the parts site
http://www.hondaautomotivepart...SHAFT
Old Jan 28, 2007 | 04:35 PM
Default Re: s20 synchro hub ? (seabass10369)
bumpage!
Old Jan 28, 2007 | 05:02 PM
EG2Driver's Avatar
get in touch with BENSE
Old Jan 28, 2007 | 05:44 PM
Default Re: s20 synchro hub ? (DeadEnd9009)
kinda figured
Old Jan 29, 2007 | 03:42 AM
anyone else
Old Jan 29, 2007 | 09:21 AM
Bense's Avatar
you have to buy a 3-4 kit which is pretty expensive. Honda won't sell just the synchro hub by itself.
take it apart and inspect the synchro sleeve. try to get pics
if the sleeve is still good i MAY have a synchro hub that will work for you.
Old Jan 29, 2007 | 09:29 AM
Default Re: (Bense)
ive already disassembled the only damaged part is that hub in picture everything else is ok
Old Jan 29, 2007 | 11:40 AM
Bense's Avatar
are you sure that the sleeve is okay? how do the dog teeth look?
I will check with my parts and see if I have a spare hub.
Old Jan 29, 2007 | 06:30 PM
Default Re: (Bense)
everything else is ok i think i broke it during/after assembly cause i didnt notice it before, however i think the was already a stress crack because i wasnt like beating it with hammers or anything
Old Jan 29, 2007 | 09:47 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (seabass10369)
I should have a few extras, check over the synchros though, the three locater tabs to be sure they are not damaged along with the blocker rings.
If you hurt the slider, I know I don't have many spares. I searched thru quite a few to send Dave @ SMS Products a good piece.
BBB tranny show it seems.......
Bone
Bauley
Bense
Old Feb 1, 2007 | 06:03 AM
BauleyCivic's Avatar
Risky Business
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">I should have a few extras, check over the synchros though, the three locater tabs to be sure they are not damaged along with the blocker rings.</TD></TR></TABLE>
You're still alive?
Old Feb 1, 2007 | 12:10 PM
Default Re: (BauleyCivic)
ok so here is the part now disassembled
Old Feb 1, 2007 | 12:36 PM
instructor74's Avatar
I am in the same boat as you I found I need the 3/4 th hub and sleeve assy and they do only come as a gear set.
Old Feb 1, 2007 | 12:41 PM
Default Re: (instructor74)
yah and unless someone on here has a spare to sell i can pick up another trans for less than the 220 for the gear set
Old Feb 1, 2007 | 05:56 PM
Mista Bone's Avatar
D Tranny Guru
I'll look tonight......should have "many".......
Bauley, I'm mainly on the D-series forums, got tired of the BS "swap it" here.
Old Feb 1, 2007 | 09:27 PM
cool
Old Feb 5, 2007 | 07:00 AM
anyone find a spare one?
Old Feb 5, 2007 | 11:34 AM
Bense's Avatar
I got one at my fathers, I'll be going down there this friday or saturday
Old Feb 5, 2007 | 05:15 PM
Default Re: (Bense)
ok well if u get it id be interested just name your price
Old Feb 5, 2007 | 05:34 PM
743power's Avatar
if Bense doesn't get it for you, I should have some here. Try him first though, I have little time to go through tranny parts.
Old Feb 5, 2007 | 07:59 PM
Mista Bone's Avatar
D Tranny Guru
I know I have a few, but was busy this weekend burying and close friends dad.
Old Feb 15, 2007 | 12:09 PM
any body find one
95LSv
Honda Civic (2001 - 2005)
Apr 1, 2010 06:09 PM
RC000E
Transmission & Drivetrain
Apr 6, 2009 02:43 PM
legomytego
Dec 19, 2008 12:21 PM
RTW DC2R
Oct 17, 2006 07:41 AM
REVolution
Sep 24, 2002 07:01 AM
