ctr pistons in a b16
Old May 16, 2002 | 09:53 PM
carcala's Avatar
Default ctr pistons in a b16
im planning on putiing ctr pistons in my b16 with stock rods. What would i need to do for it to run properly with no problems? also how should i tune it i.e .....fuel and timing????? Thanks!!!
Old May 17, 2002 | 02:42 PM
jdm civic 2000's Avatar
Default Re: ctr pistons in a b16 (carcala)
to answer your question for you,the pistons rist pins are a tab bit smaller for the rods so there for your stock rods must be shaven down a little bit for them to fit,take em to a machine shop,they will know what to do for you,do not try your self.......joe
Old May 17, 2002 | 03:52 PM
d0nkeyxPunch's Avatar
Banned
It would be a good idea to get your rods shot-peened and getting some ARP rod bolts if you are going to get CTR valvetrain.
Old May 17, 2002 | 04:34 PM
tonyxcom's Avatar
Default Re: ctr pistons in a b16 (FastxCivic)
Instead of shaving the rods, I would get the pistons milled.
We have a shop that has the program in his CNC machine to do this correctly.
Old May 17, 2002 | 04:43 PM
Katman's Avatar
Default Re: ctr pistons in a b16 (tonyxcom)
Doesn't matter. Either way works. I ran CTR pistons (milled the rods about 1-2mm) + B17A internals in a B16A3 block and it ran perfect up till the day my car got ****** stolen.
Old May 18, 2002 | 01:32 PM
carcala's Avatar
thanks for all the info guys.
Old May 18, 2002 | 03:12 PM
CRXBart's Avatar
I milled 1mm off of each side of the rod it worked great. If you think about it, the CTR rods are more narrow anyway, I don't see were milling the pistons would have any better results.
ZCSp0ngeR
10
Mar 2, 2009 08:48 PM
jdmkidd23
Apr 23, 2008 04:21 AM
Pr0j3ctxH@tchx90
12
Jul 11, 2007 09:16 AM
