HELP! 88 ACCORD LXI
I am trying to install a new exhaust on my 88 accord, got all bolts out of the flange from the exhaust to the manifold, (well, broke 2, got 1 out) there is still 1 bolt in that the nut just keeps turning on the base of the bolt, if your under the car looking up, its the one on the left side. I can get a dremel tool in there, but its not powerful enough to cut the bolt, ive tried using a flatbar to put pressure down on the nut while I try to loosen it, but this didnt work either. If any of you have any suggestions please let me know it would be greatly appreciated.
Thanks!
Rob
Thanks!
Rob
is it a stud or a bolt? see if you can get a wrench or vise grips on the other side to keep it from spinning. If that doesn't work, get a oxy-acetylene torch and cut them out, and use new bolts to re-install it.
Gonzo23
Jun 23, 2009 09:27 PM
icet
May 26, 2004 12:41 PM
