b16
Old Jan 28, 2007 | 07:46 AM
k20o2o4civic's Avatar
Default b16
swapping a jdm b16 in my ef, what is usually recommended to replace on the motor before installing?
Old Jan 28, 2007 | 07:48 AM
crxnj's Avatar
Default Re: b16 (k20o2o4civic)
seals,timing belt,water pump..or if you're paranoid like me you'll get a re-ring kit as well.
Old Jan 28, 2007 | 07:49 AM
crxpwr1's Avatar
Default Re: b16 (mr.speaker)
Change all possible gaskets, belts, fluids, and hoses.
2. Replace the clutch, flywheel, and water pump if funds permit
Edit: my bad mr speaker beat me to it
Old Jan 28, 2007 | 07:59 AM
crxnj's Avatar
Default Re: b16 (crxpwr1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxpwr1 &raquo;</TD></TR><TR><TD CLASS="quote"> Change all possible gaskets, belts, fluids, and hoses.
Edit: my bad mr speaker beat me to it</TD></TR></TABLE>
i forgot to say clutch anyway,,and if you do replace the clutch you might as well take off the flywheel and replace that damn rear main seal..
Old Jan 28, 2007 | 02:53 PM
how bout oil pump, spark plugs, plug wires. anything else.....where can i go to get OEM parts, if i go to the dealer, i have to ask under Del Sol, right? or would the new 99-2000 civic si parts match up as well?
Old Jan 28, 2007 | 04:28 PM
oodie's Avatar
Default Re: (k20o2o4civic)
*Distributor Locashracing.com has new OBDO for $275
*Distributor Hmotorsonline.com has used OBDO for $150
*Transmission Oil Seal. Beck/Arnley #0523545
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol **this did not work for me, too long. I used the D16a6 Si belt**
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
*Shift Linkage Pin A94305-80222
*Shift Linkgae Pin Clip A54113-611-010
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets -8- 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK---- Stock Number 5724 in case they cant use the NGK #
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
*The rubber seal for the distributor cap is 30132-PM5-A02 (90-91 Integra)
*NAPA part #25-040300 for the alternator and a/c
gooberwolf
Aug 27, 2013 08:59 PM
meagainsttheworld
20
Sep 5, 2006 07:44 PM
aZnjCC
Mar 6, 2006 07:09 AM
JDM_Type-R
Jan 27, 2005 12:36 AM
civicracer99
Aug 25, 2003 01:32 PM
