OEM Oil filter confusion, any help??
Old Jan 28, 2007 | 12:04 AM
chomorro's Avatar
Default OEM Oil filter confusion, any help??
I haven't changed my own oil in years because i got in trouble removing engines etc in the front yard.....Anyways i wanted to change my own oil this time around so i went to the dealer to get my oil filter and they gave me one that is much smaller then the one i have on there already. My mechanic who changes my oil uses a bigger OEM filter. The dealership told me they have switched to smaller filters that fit almost all Honda engines. So heres my question, my mechanic has been using the bigger filters and honda says its ok to use the small filters. Has anyone had any problems using the smaller filters????
Old Jan 28, 2007 | 04:08 AM
iam7head's Avatar
Default Re: OEM Oil filter confusion, any help?? (chomorro)
the smaller filter is good, they change it like a year or so ago.
too bad most of the oil filter gripper can't fit the slim filter.
they pretty much replaced the whole line of the filter except for couple of honda
Old Jan 28, 2007 | 05:29 AM
Centripital's Avatar
Nope, no problems here. Yes, I've heard the change applied to the entire filter line except the one for the S2000.
Old Jan 28, 2007 | 08:12 AM
CBL9's Avatar
Does it hold the same amount of oil anyone know? The older one was wider and shorter, the newer one is longer and skinnier whats the deal?
Old Jan 28, 2007 | 09:16 AM
iam7head's Avatar
Default Re: (CBL9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBL9 &raquo;</TD></TR><TR><TD CLASS="quote">Does it hold the same amount of oil anyone know? The older one was wider and shorter, the newer one is longer and skinnier whats the deal?</TD></TR></TABLE>
i don't think they hold as much based on the size difference from the outer shape.
honda's new filter suppose to bump up the oil pressure which is good
Nooch
Sep 10, 2011 02:07 PM
redDAinteg
Sep 3, 2007 12:19 PM
mfisher1967
Honda Civic (2006 - 2015)
Jun 23, 2007 06:57 PM
silentdeath12886
Dec 18, 2006 04:04 PM
EKB18BPR3
Aug 18, 2002 02:43 PM
