4x114 to 5x114 conversion thingy any good?
Old Jan 27, 2007 | 09:30 PM
camil212's Avatar
Default 4x114 to 5x114 conversion thingy any good?
I was wondering if these conversion plates were a good thing to do or is it a waste of money? they also change the offset a little. The wheels I'm planning on are 5 lugs and a 5 lug conversion it's too expensive. I hate 4x114
Old Jan 27, 2007 | 09:44 PM
hu's Avatar
hu
What conversion plates? What am I missing!
Old Jan 27, 2007 | 09:52 PM
camil212's Avatar
Default Re: (hu)
it's a round piece that looks sort of like a wheel spacer and it bolts onto the 4x114 hub leaving 5 studs where you would install your 5 lug rim on. they sell on ebay or any performace shop.
Old Jan 27, 2007 | 10:07 PM
hu's Avatar
hu
Damn, I must be behind the times being so old and all! I will have to look into this.
Old Jan 27, 2007 | 10:12 PM
camil212's Avatar
Default Re: (hu)
I was just wondering if anyone have done it here? by the way these plates will affect the offset of the wheel a little meaning the wheel will stick out a little if you don't find something above +50 for a 4th gen. the higher the offset on the wheel the better
Old Jan 27, 2007 | 10:52 PM
M@'s Avatar
M@
Default Re: (camil212)
seems like the plate would need to be atleast as thick as the lug studs.
Old Jan 28, 2007 | 12:14 AM
BlownH23a
Guest
Posts: n/a
my friend had them on his gsr, they worked just fine until he put some real tires(nt555r) on then they started to twist under the stress...he got them from a local speed shop. try finding some that are titanium or carbon steel.
Old Jan 28, 2007 | 09:39 AM
shutta's Avatar
or just do a proper 5gen knuckle swap...
Old Jan 28, 2007 | 10:25 AM
1GPlusSH's Avatar
Default Re: (shutta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutta &raquo;</TD></TR><TR><TD CLASS="quote">or just do a proper 5gen knuckle swap... </TD></TR></TABLE>
And the good thing about the swap is you have a lot more rims to choose from
Old Jan 28, 2007 | 07:20 PM
BlownH23a
Guest
Posts: n/a
i second the knuckle swap...titanium or carbon steel adapters would probably cost more then the swap it self anyways
shaggyeg6si
Apr 21, 2008 10:41 AM
BlueLude 94
Jan 24, 2006 10:55 PM
mr2slo4u
Oct 14, 2004 08:21 PM
Project X
Jun 29, 2004 07:06 AM
ZoNe_HKS
May 2, 2003 09:45 AM
