ps removal kit???
im currently gonna purchase a ps removal kit, well the dc teg have 3 ps lines in rack, and the kits have 2 line for them,what should i do??? only hook up the two like ur supposed 2 do and block the one off or what? lemme know what u other people did.
i just recently did mine. i think its only two ps lines going into the the whole bracket. if you actually want to save money loop it around and put some ps fluid in it before tightening it up. but you will need to buy one more male insert into the ps bracket or just cut it off and loop it around.
Save your self some money and just buy one fitting to replace the hardline, then just use existing hoses to loop the lines.You can also make a breather out of almost anything to add into the looped lines.
so are u guys saying just loop them all together,which i already know,but hook all 3 together and put the breather on it?? no my dc teg has 3 hardlines in the rack. 1 for the ps pump that bolts to motor, then the 2 that wraps up to the resevoir. thnx for the post
