power steering cooler removal? bad idea?
Old Jan 27, 2007 | 03:44 PM
John Z's Avatar
Default power steering cooler removal? bad idea?
i picked up an oil cooler kit that happens to fit in the same spot that the power steering cooler does. and my first thought was hell delete PS... but im a bitch and i like my PS, so i was thinking about just looping the lines so there is no cooler. has anyone done this? do you think it would be a bad idea? i do track the car but idk if PS fluid gets that hot to need a cooler.
Old Jan 28, 2007 | 12:16 AM
OG undercover's Avatar
Default Re: power steering cooler removal? bad idea? (Yaz)
Your search for "power steering" returned 23 results.
Old Jan 28, 2007 | 07:24 AM
John Z's Avatar
Default Re: power steering cooler removal? bad idea? (AwesomeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AwesomeR &raquo;</TD></TR><TR><TD CLASS="quote">Your search for "power steering" returned 23 results.</TD></TR></TABLE>
your search for power steering comes up with a shitload of how to delete it... i already know u can either loop it or T it off....
since u came up with 23 results why dont you be a gem and post up somthing useful to me...
edit:
my search came up with 66...
u see anything i can use in that?
Old Jan 28, 2007 | 07:51 AM
crxgator's Avatar
hahaha i knew this was going to happen...
Yazwned...
Old Jan 28, 2007 | 08:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yaz &raquo;</TD></TR><TR><TD CLASS="quote">
u see anything i can use in that?</TD></TR></TABLE>
Work?
how about paying?
The American way.
Old Jan 28, 2007 | 11:38 AM
John Z's Avatar
Work?
how about paying?
The American way. </TD></TR></TABLE>
work?
pay?
huh?
i have a job?
eh either way, o well.
Old Jan 28, 2007 | 12:39 PM
In other words... find it yourself.
Old Jan 28, 2007 | 01:15 PM
Kavehman's Avatar
Unfortunantly todays noobs like AwesomeR just have big mouths, and really don't know **** which is why they respond in the way they do.
To answer your question, I would not get rid of the cooler (you do need it) but it can be relocated in a different location, you could try extending the lines.
Old Feb 2, 2007 | 09:15 AM
drumminforev's Avatar
Default Re: power steering cooler removal? bad idea? (Kavehman)
why exactly is it needed and what would happen if you removed it.
Old Feb 2, 2007 | 10:51 AM
John Z's Avatar
im going to update this thread when i get home, im at work right now.
i was able to relocate it and fit the greddy oilcooler kit
Old Feb 2, 2007 | 01:52 PM
ZygSpeed's Avatar
Default Re: (Yaz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yaz &raquo;</TD></TR><TR><TD CLASS="quote">i was able to relocate it and fit the greddy oilcooler kit</TD></TR></TABLE>
I would like to see a pic of that because I may be doing the same.
Thanks.
Old Feb 2, 2007 | 04:41 PM
John Z's Avatar
Default Re: (Yaz)
sorry they are huge for now, ill edit it soon:
the stock PS cooler has the U shape then an offset it connects to the stock rubber lines.
pretty much what i did was cut the U shape at the ends just before the offset and used hose about 3feet long cut it in half, and connected the ends to the stock hard lines running down the frame.
the only thing i wish i had was the tool to flair the ends of the PS cooler lines.when i get a chance i may pull the bumper off and do that.
Old Feb 6, 2007 | 04:18 PM
Default Re: (Yaz)
again why is a PS cooler needed
DelSol12345
Aug 26, 2008 08:41 AM
egmatt93
11
Mar 10, 2007 09:35 AM
digital sol
Dec 31, 2005 04:06 AM
volcomstoned
Nov 15, 2005 04:10 PM
DAintegraGSR
Jul 19, 2005 10:16 AM
