Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
exhaust issues
Old Jan 27, 2007 | 06:29 AM
oneman2halves's Avatar
Default exhaust issues
A year ago i purchased a 2002 civic lx, since then i have been deployed in afghanistan.. over here my resources are limited my question is if i replace the exhaust (included header) and used the EX parts is it 100% compatable?
Old Jan 27, 2007 | 08:35 AM
Miracle's Avatar
Default Re: exhaust issues (oneman2halves)
Like you mentioned... to replace the exhaust on the LX, to EX specs, with an external cat, you would need the ENTIRE exhaust stream past the cylinder head... to include:
Manifold
B-Pipe/Cat converter
And if you want to avoid fabrication to get the LX cat back to bolt up to the EX cat pipe, you will need an EX cat back. The exhaust connections on the EX pipe, and the LX cat back are different. So unless you plan on welding, just get an EX cat back too.
Hope that helps.
Old Jan 27, 2007 | 10:24 AM
Tiauna's Avatar
I was just wondering that same question cool now I think I will get the skunk2 cat back now.
Old Jan 27, 2007 | 10:37 AM
Vantage's Avatar
just dont forget u need a cat.
Old Jan 27, 2007 | 05:43 PM
Tiauna's Avatar
I am catless
Old Jan 28, 2007 | 01:47 AM
Default Re: (Tiauna)
Thank you!
one last question should i go ahead with the high flow cat or just replace it with an EX cat
Old Jan 29, 2007 | 12:15 AM
Curiouz_G's Avatar
ex cat. unless your boosted, no need to go high performance cat
milkmanLCA
36
Apr 22, 2010 04:10 PM
1991EX
Sep 11, 2007 08:26 PM
Kidnkorner
Nov 16, 2005 07:59 AM
Project_Civic
Apr 5, 2005 03:30 PM
RickChew
Feb 17, 2003 12:03 PM
