what causes white smoke on start-up ??
hey guys
well today is actually the first time i found out that my car blows white smoke on start up just for like 2-3 secs after its been sitting like 30mins of so, its not a lot of white smoke but its enough to see that there's actually smokes coming out of the tail pipe
i just recently changed the oil and hosed off the engine bay
my spark plugs looks nice and dry
on my old oil there was no sign of coolant present
can anyone help me and make my day please
thanks guys
thanks guys
nah i know for sure its not condensation
its summer where i live at the moment
its like first time i start up the car in the morning it would smoke for like 2-3 secs then stops....... drive the car ........ park the car for say 30mins...... start it up...... white smoke comes out again
headgasket might be starting to go?? that happend to mine just alittle white on start up and it turned out to be my headgasket coolent was leaking in to the cylanders and burning and making it smoke white
is the coolent fogy? open your oil cap and look at the oil cap and see if it looks creamy it might be the very begining stage of gasket problems but i might be wrong hopfully but thats the only thing i can think of
nope, on the bottom of my oil cap theres no milky colour at all
my radiator cap looks clean, and the water also still clean green
do you think its got something to do from me cleaning the engine bay with garden hose ???
doubt it tho .....
cnofused confused help help help
doubt it tho .....
yupe i covered my turbo, dizzy cap, ext coil, cdi ignition even the battery
all covered with plastic bags
i just went for a drive giving it hell, car pulls hard still
and from personal experience if i had a blown headgasket the water in the resevoir bottle should be all the way full right ??
but i just checked, it stays the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyber ITR »</TD></TR><TR><TD CLASS="quote">the oil return line for the turbo ??
sorry not really mechanically minded person
The oil return is where the turbo drains the oil back into the oil pan.
They are saying to check that and see if there is a rescrition in the line that could be cause the oil to back up.
Yes a leak down can tell you quite a few things about the motor including where the motor is leaking from if it's leaking
</TD></TR></TABLE>The oil return is where the turbo drains the oil back into the oil pan.
bump
i started up the car and the white smoke doesnt have that sweet-coolant-burning smell
im really confused
when i washed the engine bay i sprayed degreaser all over the place, would it be some unwashed degreaser burning off ?? dont think so
HELPP !!!!
im really confused
HELPP !!!!
Have the exact same problem. My oil drain is fine and I am not losing any coolant either, we're in the same boat
The funny thing is, I also degreased my engine bay not too long ago
Smoke was present before though so yea that can't be it. Bump for some more opinions!
