Where does starter solenoid lead originate?
Old Jan 26, 2007 | 11:29 AM
Jonathan_ED3's Avatar
Default Where does starter solenoid lead originate?
I bout a hatchback for cheap that had a crappy alarm system and stereo install.
I ripped all the old alarm system out, old stereo etc and rewired the stock harness.
Well now the car won't start. It just clicks. I got to looking around, and I don't have anything hooked up to the starter solenoid. I don't know how I ripped it out too, but I did.
I suspect this is my problem. Where does the starter solenoid lead originate? The small wire with a spade terminal on the end, not the large wire that comes from the battery. I want to wire it back up, but I don't want to blow anything.
Old Jan 26, 2007 | 11:31 AM
dwerpk's Avatar
if im thiknin of the correct wire i think it goes into the fuse box on the shock tower
Old Jan 26, 2007 | 12:29 PM
Yes, but I need to know exactly where to connect it. I don't have any of the lead at all.
Old Jan 26, 2007 | 12:43 PM
jlicrx's Avatar
Default Re: Where does starter solenoid lead originate? (Jonathan_ED3)
the wire originates at the ignition switch (black with white stripe) and runs into the under dash fuse box and then to the starter relay - comes out of the starter relay as black with red stripe and runs back to the under dash fuse box to fuse #2 - comes out of the fuse box at fuse #2 as black with white stripe and runs to the starter solenoid
Old Jan 26, 2007 | 12:56 PM
Thanks jlicrx. Wired it up to the black with white striped wire coming out of the ignition leads and it works perfect now.
Thanks again!
ShiroZ31
Dec 10, 2013 01:13 PM
akouznet
May 29, 2009 11:12 PM
j-bird20
Oct 22, 2007 07:52 AM
1Bluegsr
Oct 3, 2007 01:47 PM
tgreaves
Jan 3, 2005 01:50 PM
