Need Help Civic windows
Hi,
I just bought a Civic and the window will not roll up. No power windows. Seems like the glass needs to be adjusted. How do you remove the door panel to get to the inside of the door? Any help will be appreciated.
Thanks
Thanks
theres 2 screws, one on the door handle and one on the door grip. you also have to remove the window regulator handle which is held on by a pin. once you have those off you most likely have more screws located near the speaker grill. get those off as well then you can pop the panel off.
It's been a while since I've taken the panels off in my car, but I think I remember how to do it:
1) you'll want to unscrew the door handle trim and the thing where the window switch normally is (I know you don't have power windows, but I don't know what the things called, so yeah.. ). To unscrew the handle trim, pull the door handle and there will be a screw behind the handle near the top.
2) Pull out the bottom of the door panel. The clips should come out easily enough.
3) If you have power anything related to the door or if you have tweeters in the door panel, you'll need to disconnect the plug thing.
I think that's about it...
1) take out the screw in the door handle trim peice
2)take out the screw from the door grip
3)take out the C clip from the window crank, should be able to use either needle nose or try fishing it out with a flathead screwdriver
4)pop the bottom speaker grill off
5)unscrew alll the screws for the speaker and disconect it
6)there should be like 3 screws to the out side of the speaker
7)just pry the bottom of the panel out and lift up
casper.hughes
Oct 12, 2008 06:33 PM
DRAG1320ciVHBKsi
Nov 29, 2002 09:50 AM
