dsm's are 450cc, but at what psi was this measured?
Old Jan 25, 2007 | 08:51 PM
hxtasy's Avatar
Default dsm's are 450cc, but at what psi was this measured?
what psi are the dsm's measured at? can't seem to find any manufacture specs on them.
Old Jan 25, 2007 | 10:25 PM
s2kdre's Avatar
Default Re: dsm's are 450cc, but at what psi was this measured? (hxtasy)
what are u trying to find out? how much power per injector is possible?
Old Jan 25, 2007 | 10:31 PM
Ryan15's Avatar
Default Re: dsm's are 450cc, but at what psi was this measured? (s2kdre)
stock 1g fuel pressure is 37psi, and 2g is 43psi, if you had a stock gs-r with, 48psi you would be flowing considerely more.
Ryan
iBrandon's Avatar
you can do sum self testing if you want by opening one injector off the fuel rail...get a cup or cylinder with measurements on it and if u have a FPR...adjust different pressures until it fills the cup or cylinder up correctly...just an idea!
Old Jan 26, 2007 | 03:59 AM
HiProfile's Avatar
Default Re: dsm's are 450cc, but at what psi was this measured? (Ryan15)
You need 4x the fuel pressure to flow 2x more fuel. If for some reason your stock gsr was running 48, you'd be flowing 14% more. Otherwise, it would be ~6% more if you were running the stock 42psi.
Old Jan 30, 2007 | 03:53 AM
hxtasy's Avatar
Default Re: dsm's are 450cc, but at what psi was this measured? (iBrandon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBrandon &raquo;</TD></TR><TR><TD CLASS="quote">you can do sum self testing if you want by opening one injector off the fuel rail...get a cup or cylinder with measurements on it and if u have a FPR...adjust different pressures until it fills the cup or cylinder up correctly...just an idea! </TD></TR></TABLE>
i like you
Old Jan 30, 2007 | 04:07 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hxtasy &raquo;</TD></TR><TR><TD CLASS="quote">what psi are the dsm's measured at? can't seem to find any manufacture specs on them.</TD></TR></TABLE>
most injectors i have seen are flowed @ ~45 psi
RC engineering
the.hamburglar
Mar 27, 2015 07:58 AM
Calvinator
Jul 30, 2006 09:03 AM
blue_hatch
Mar 6, 2005 11:39 PM
sleepin91teg
Jun 16, 2004 05:13 PM
X2BOARD
Apr 10, 2004 03:31 PM
