What to grease when windows start sticking?
When I put my driver's window down, it goes down great until about the last 3", when it seems to start sticking and going down really slow - sometimes it won't go down unless I push it down to help it. The passenger's window is worse...it's slow right from the top, and gets progressively worse. I know it COULD be the motor going bad, but I'd like to try greasing it up first. What exactly would I grease?
Check the regulators and the rails first... It could be binding on those last 3" of travel... I'm not sure what it's greased with, but more than likely it's either lithium grease or silicone lube...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCejcivic »</TD></TR><TR><TD CLASS="quote">silicone spray. spray it in the runs (where the window slides) and put the window up/down...repeat if necessary. ******* will fly up and down afterwards...</TD></TR></TABLE>
everyone is sitting quietly in my school library and i laughed out loud after i read that
my one window sticks at the top,
after i help "unlock it" it'll work fine from there
should i silicone spray inside the top window frame or am i going to have to look inside the door?
I had this **** happen to my car as well. First take off the entire door panel and the plastic weather stripping to make sure the window is on track. Then spray silicone on the tracks and the run channel so that it gets lubed up.
Newhondawhothis
Feb 19, 2018 03:46 PM
strictly.business
15
Nov 28, 2006 11:20 AM
EGcivicBoy
Dec 15, 2003 09:52 PM
