I'm kinda torn between N/A or F/I
Old Jan 25, 2007 | 06:22 PM
ShApE's Avatar
Default I'm kinda torn between N/A or F/I
Hi guys!
As the title says I'm a little confused on which route I wanna go with my soon to be Del Sol. My last car was a 400whp 944 turbo and I spun a bearing on the dyno after a year of bulding it. As you probably already know Porsche parts are EXPENSIVE! Even if they were for the bastard child 944. So now I'm looking for something to build and I've decided to go with something completely different, a Del Sol. Don't ask me why lol, I've just always had a soft spot for them.
So, now that you have my life story and we've shared some good times and some bad times, I'm asking for your input.
I'm not sure if I should go with a "mild" turbo setup (like 220whp) on stock engine and still have it be somewhat reliable. Or I kinda wanna go with a h22 swap (h2b) with 4-1 header, CAI, maybe cams, and exhaust. Now before you preach to me about the 30 extra pounds the h22 brings, It's really not a huge deal to me. Basically I'm just trying to have decent power without spending a ****-ton of money and still keep it somewhat reliable.
Sooooooo, what do you think?
Old Jan 25, 2007 | 06:45 PM
BlueIntegraBoy's Avatar
Default Re: I'm kinda torn between N/A or F/I (ShApE)
An N/A setup will cost a lot of money to reach a certain goal compared to a turbo setup with the same goal. Turbo can be reliable as long as it was installed correctly with the proper fuel manangement.
If you are looking for 220whp, it will take a lot of money N/A wise, while a turbo setup can easily reach that.
Old Jan 26, 2007 | 04:18 PM
ShApE's Avatar
hmmm, I was under the impression that the h22 came with around 180-190 hp? I figured with minor work I could squeeze about 210hp out of it. Am i dreaming here or what lol?
Old Jan 26, 2007 | 05:10 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: (ShApE)
thats flywheel, you want fwhp, which comes with a little less, but loik at the cost of the h2b kit, h22 and b16 trans, mounts, ecu for the h22 harness, etc man the h swaps get pretty expensive if you pieace together a dseries turbo (200 whp easy) itll be easier and cheaper
Old Jan 26, 2007 | 05:12 PM
bmoua's Avatar
y the h22 power plant? i'd stick with the b-series. just my opinion
Old Jan 26, 2007 | 05:14 PM
EJ6_ROY's Avatar
Default Re: I'm kinda torn between N/A or F/I (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">.
If you are looking for 220whp, it will take a lot of money N/A wise, while a turbo setup can easily reach that.</TD></TR></TABLE>
On an H22?????? You could damn near achieve that with bolt-ons/tuning. throw some high compression pistons in the mix and for a nice setup. my .02
Old Jan 26, 2007 | 05:35 PM
DJ_SaNdOz's Avatar
Default Re: I'm kinda torn between N/A or F/I (rniederlando)
H22's are good motors. An H22 with a CAI, RMF or SMSP header, exhaust, and some Type S pistons you should see somewhere between 200-220 whp. This will be expensive.....
Used Greddy turbo kit + tuning = 220 whp for significantly less.......
Old Jan 27, 2007 | 12:52 PM
ShApE's Avatar
alrighty, Thanks for all of the input and advice. I think I'll just make **** cheaper for myself and go with a turbo setup.
Old Jan 27, 2007 | 01:05 PM
bart2546's Avatar
Default Re: (ShApE)
I'm a personal fan of forced induction and I feel that they can be very reliable when done right with good quality parts..as you'll see a lot on this site, the TUNE is what makes everything reliable. Personally...I think 220 is a realistic goal and can be done safely on a stock motor with stock internals. Good luck on your build though and keep us updated with pics!
Old Jan 27, 2007 | 01:29 PM
cyang08's Avatar
if you wana go N/A go with the K-series. if not then just get a turbo Kit. i like turbos so i would go witht the turbo. its just more kool to see a turbo kit inside of your engine bay then if it was just a plain engine. turst me even if you just turbo your D series engine you can make it look kool. and you can also make it high horse power if your pockets are deep. thats just what i think.
Old Jan 27, 2007 | 02:39 PM
team1320_k26eg's Avatar
Default Re: (cyang08)
i think k series is sick but turbo are schweet also... so do both hehe
Old Jan 27, 2007 | 02:59 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (team1320_k24eg6)
H2B
Wave of the future son!
Disgustipated
34
Jan 21, 2011 02:23 PM
Jerrod H
Sep 16, 2007 03:31 PM
95Delly
Jan 20, 2006 09:08 AM
leebabin387
Oct 6, 2005 08:34 PM
wesleyinsanho
Feb 9, 2004 03:10 PM
