Anyone With Shop Manuals, Can You List Ignition Coil Specs ?.....
Old May 16, 2002 | 04:18 PM
JSIR's Avatar
New User
Default Anyone With Shop Manuals, Can You List Ignition Coil Specs ?.....
Just wondering if anyone that has an ITR shop manual can list the specs for the ignition coil. It should be listed at the front of the manual in the specs section (section 3 ?). Specifically the primary widing resistance and secondary winding resistance ranges as listed. I guess there may be two different coils listed, the TEC coil is good enough if there are two listings. If anyone could post that it would be appreciated. Just want to compare it to other coils. thanks.
Joey
Old May 16, 2002 | 04:33 PM
t's Avatar
t
Default Re: Anyone With Shop Manuals, Can You List Ignition Coil Specs ?..... (JSIR)
Primary voltage 12Volt
Primary winding resistance at 68F 0.6-0.8 Ohms
Secondary winding resistance 68F 12.8-19.2 KOhms
Old May 16, 2002 | 04:41 PM
JSIR's Avatar
New User
Default Re: Anyone With Shop Manuals, Can You List Ignition Coil Specs ?..... (t)
hey thanks for the quick reply, hmmm ,looks like the same spec as the b16a coil, no difference., must use the same coil then. thanks again.
Joey
CrAcKiN-VTEC
Aug 17, 2009 04:29 PM
crazyc@SRTmotorsports
Mar 11, 2007 12:59 AM
integra93turbo
Sep 24, 2006 05:09 PM
gutted
Feb 22, 2006 08:47 AM
Charlie Moua
Mar 23, 2004 05:13 AM
