anyone with "jdm itr 5 lug" axle?
Has anyone tried using the crv axle or prelude axle which both have a 36mm outer? which axle would drop in without any swapping of outerjoints? thanks
I was hoping someone would know exactly which axle i can use.
I looked at the crv axle and it looks a lil longer so I dont think crv axle will do.
next im goin for a prelude axle but all the shops around me dont stock em. I dont want to order them and have to pay a restocking fee if they dont fit.
Anyone know 100% if the 98+ prelude axle will work??
Modified by kpop at 8:51 PM 1/25/2007
crv axels would work on something with a bseries swap as long as it was a pre-k24 axel (i dont know the years). I've heard of people doing it, but no first hand experience.
Im doing 5-lug in like a month here, and the easiest thing to do is just ger the CTR 5-lug. Your stock axels will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eg2james »</TD></TR><TR><TD CLASS="quote">crv axels would work on something with a bseries swap as long as it was a pre-k24 axel (i dont know the years). I've heard of people doing it, but no first hand experience.
Im doing 5-lug in like a month here, and the easiest thing to do is just ger the CTR 5-lug. Your stock axels will work.</TD></TR></TABLE>
Yes, the ctr 5 lug would be easier. Unfortunately I already have jdm 5 lug with the rears already installed. If the crv axles work I wont have to worry about axles later on down the road.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpop »</TD></TR><TR><TD CLASS="quote">
Yes, the ctr 5 lug would be easier. Unfortunately I already have jdm 5 lug with the rears already installed. If the crv axles work I wont have to worry about axles later on down the road.</TD></TR></TABLE>
yeah you're good to go. seen it done more then once
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX »</TD></TR><TR><TD CLASS="quote">which axles from what car work for the ctr/itr swap? i'm assuming z6?</TD></TR></TABLE>
can you rephrase that?
if your asking what axles work for a hub swap, the crv ones will work on any eg/dc/ek ect. when you have the itr setup.
did you mean d16z6 axels...? i think these would only work with the ctr hub swap, nothing else. if you have the itr hubs, you must have a b series swap so you can use the crv axels.
EFM_ookie
16
Aug 14, 2005 09:27 PM
