check engine light
Old Jan 25, 2007 | 07:48 AM
DC5StylZ's Avatar
Default check engine light
i just gota cai/sp2 cat and a dc race header my buddy said im gona throw a check engine light all the time is this true can i fix it ......????
Old Jan 25, 2007 | 08:57 AM
dc5tegk20's Avatar
Default Re: check engine light (DC5StylZ)
unplug your battery one more time to try and reset it, it should go away but im not 100% sure because of the hole non cat thing, other than that when you turn the key on to the accessory it will stay on and then blink like 5 timesw because everytime you reset the battery the car looses emisions controlls and through standard driving it will eventually reset itself.
Old Jan 25, 2007 | 11:55 AM
DC5StylZ's Avatar
Default Re: check engine light (dc5tegk20)
sory i forgot to include the letters "jdm" , cause thats the only way people look
Old Jan 25, 2007 | 05:41 PM
jdmrazing's Avatar
as long as you have both o2 sensors plugged in and not modified, and all other sensors are used properly, then you wont get a light, if you do and the car runs fine, then that is just the way it works.
Old Jan 25, 2007 | 06:06 PM
typedc5's Avatar
you may need a defouler escp on an 05-06 since you installed a race header.
brycecubes
Apr 29, 2011 09:32 PM
ThinHoanG
Mar 9, 2005 11:10 AM
pbizzlegsr
Apr 4, 2004 11:46 PM
ramz7887
Dec 3, 2003 09:44 PM
Memo6453
Feb 11, 2003 10:26 AM
