high compression
Old Jan 25, 2007 | 12:44 AM
greeneg2.0's Avatar
Default high compression
i have setup b20vtec with stock sleeves and the 84.5mm and copression 11.5 and my head fullybuilt and want to run higher compression ,more than 13.1 compression and i have a dtr header i just bought and my old setup i ran 12.00 at 111 mph and want to go faster and just for the track .my goal to hit mid 11's or low 11's
Old Jan 25, 2007 | 02:16 AM
BuiltforSin's Avatar
ok... and your question is..................?
Old Jan 25, 2007 | 08:28 AM
nokturnal_munkeeboy's Avatar
Default Re: (mugenej8power)
what is the question dude
Old Jan 25, 2007 | 08:49 AM
d16dcoe45's Avatar
Default Re: (nokturnal_munkeeboy)
Have you tried FULLY optimizing the setup you have now? I mean, getting the best fueling, ignition timing, and cam timing? Tried every combination on the dyno/and or the track? On 99% of "tuned" motors, there are always a couple horses to be picked up by fully optimizing the motor for EXACTLY what you plan to do with it.
It takes alot of time, and alot of different combos to find couple that work well.
Old Jan 25, 2007 | 09:41 AM
greeneg2.0's Avatar
Default Re: (d16dcoe45)
should i run higher compression and would i
make more power?
Old Jan 25, 2007 | 11:33 AM
soulpwr's Avatar
Default Re: (greeneg2.0)
a bump in compression will indeed make more power. Will your stock cylinder walls handle it without cracking? Thats the question. BearsEK seems to get away with 14:1 but others have seen problems with compression much lower than that.
the_yblegal
Engine Management and Tuning
Jun 2, 2014 04:50 PM
Ideal
Jan 2, 2004 12:12 AM
HX_Guy
Dec 6, 2001 03:24 PM
