Starter Rebuild
I know this is for a bseries but will the same part numbers work for any h series ?
http://www.team-integra.net/se...=1079
So when u buy a rebuilt starter this is all they really do internally ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">Just buy a new one from advanced that comes with a lifetime warranty.</TD></TR></TABLE>
+1 why monkey with it when it can be a simple unbolt, bolt back on, tension and such then your ready. Self refurbishing things is asking for trouble later imo unless you are good.
I just rebuilt mine (well I actually changed parts over from a similar starter). The prelude starter look nothing like that one!
I basically just opened it up and changed the parts and gave it a good clean. After that my starter worked great!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_lude »</TD></TR><TR><TD CLASS="quote">I just rebuilt mine (well I actually changed parts over from a similar starter). The prelude starter look nothing like that one!
D.I.Y
Modified by E-Money at 11:14 PM 2/9/2007
D.I.YModified by E-Money at 11:14 PM 2/9/2007
A trick to get the old contacts off the bolts is to stick a 12MM socket over the bolt head, put the end of the bolt against a table and give it a light tap with a hammer. The contact should seperate. Put the new contact on and put the socket over the other and and tap to secure it in place.
Anyway, an easy way to tell if your contacts are bad is if you turn your key and nothing will happen, but if you keep trying it will eventually start up. Happens more often in the cold. Anyway, be happy B/H series starters are easier to remove then on a 4Runner
