tranny question
Old Jan 24, 2007 | 03:47 PM
Skipper75's Avatar
Default tranny question
today i was driving and after about 20 minutes of street driving it started to get harder to get it in the different gears.
i almost couldnt get it in first and second near the end of my travel.
it usually is pretty smooth atleast for the first few minutes of driving.
no leaks and it has new tranny fluid.
could it be heat? shift linkage moved or something? clutch engagement change?
Old Jan 25, 2007 | 03:20 AM
Skipper75's Avatar
Default Re: tranny question (Skipper75)
hmm i'll bump this once and try to figure it out on my own i guess.
Old Jan 25, 2007 | 05:41 AM
ILcrxsi1's Avatar
I tell doctors what to do
check your clutch cable adjustment
Old Jan 25, 2007 | 07:56 AM
DaX's Avatar
DaX
Loved
Community Favorite
With your car turned off in your driveway, push in the clutch and try shifting into all your gears. Is it easy? If so, then you probably need to adjust your cable.
Old Jan 25, 2007 | 08:23 AM
ILcrxsi1's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">With your car turned off in your driveway, push in the clutch and try shifting into all your gears. Is it easy? If so, then you probably need to adjust your cable.</TD></TR></TABLE>Yes, just try reverse. If it grinds, tighten up that cable. You have to press in the clutch and give it a couple seconds first or else it will grind anyway.
Old Jan 25, 2007 | 12:00 PM
Gearspeed-Performance's Avatar
Default Re: (ILcrxsi1)
What tranny fluid did you use....please don't tell me you used gear oil...
C-RICKS
Jul 8, 2006 11:38 AM
SiBuddy00
Jun 21, 2005 07:57 PM
teewhy55
Dec 15, 2004 03:17 PM
Grease Monkey
Jul 15, 2004 01:34 PM
.nate
Sep 12, 2002 12:47 PM
